Hackaday.io Hackaday.io
Sign up Log in
Component Tester (V-I Curve Tracer)
Component Tester (V-I Curve Tracer) Using The Oscilloscope
hesammoshirihesam.moshiri
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.3k views
0 comments
6 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1.3k
0
6
2
Team (1)
  • hesammoshirihesam.moshiri
Join this project's team
hardware
ongoing project
oscilloscope xy mode curve tracer component test diode test
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 10/01/2020 and last updated 5 years ago.
Description
Component Tester (V-I Curve Tracer) Using The Oscilloscope XY Mode
In this video, I've talked about the XY mode/feature of a Siglent SDS1104X-E oscilloscope and used it in a combination with a Siglent SDG1025 waveform generator to show how you can build an interesting component tester (V-I curve tracer) to test silicone diodes, Zener Diodes, Schottky diodes, LEDs, Resistors, transistors, capacitors .. etc. Also, you can use it to learn about the behavior of the components and semiconductors. You only need to follow a very simple circuit (schematic) and hock the probes to the correct circuit points.
In the video, I have tested these components: 330-ohm resistor, 1N4007 diode, 1N4148 diode, 1N5819 Schottky diode, a white LED and a green LED. the memory depth of the oscilloscope was set on 7M.
Details
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Component Tester (V-I Curve Tracer)", please tell us the reason.
Send message
Remove Member
