Here is the second version of the Uglytech relay. I will try this for signal isolation to the typewriter/printer. Still needs work but getting better at this...
This video shows that the relay does work with both IO and the printer Note the screw and nut added to adjust gap.
Dr. Cockroach
While playing with various voltage/current levels, I found that I needed to make the throw adjustable :-)
Adjustable throw and everything, nice one Doc. :-D
