Orbit length invariance
A project log for miniMAC - Not an Ethernet Transceiver
custom(izable) circuit for sending some megabytes over differential pairs.
yann-guidon-ygdesYann Guidon / YGDES 11/12/2025 at 20:270 Comments
Testing the new modulus, I check the effect of a constant input message.
Msg=0:
66000000000  X=36663    Y=131746
66100000000  X=159181    Y=42180
66200000000  X=56730    Y=127039
66300000000  X=93853    Y=158451
66400000000  X=36243    Y=165031
66500000000  X=71790    Y=65041
66600000000  X=80476    Y=43666
66623095107     done !
Msg=1:
66000000000  X=236773    Y=175058
66100000000  X=143693    Y=108851
66200000000  X=227833    Y=190930
66300000000  X=246629    Y=237951
66400000000  X=151749    Y=33828
66500000000  X=162761    Y=46437
66600000000  X=16165    Y=215837
66623095107     done !
Msg=2:
66000000000  X=178770    Y=218371
66100000000  X=128206    Y=175522
66200000000  X=140823    Y=254822
66300000000  X=141292    Y=59338
66400000000  X=9141    Y=160740
66500000000  X=253732    Y=27833
66600000000  X=209968    Y=129893
66623095107     done !
Msg=3:
66000000000  X=120766    Y=3570
66100000000  X=112718    Y=242193
66200000000  X=53813    Y=60600
66300000000  X=35955    Y=138839
66400000000  X=124647    Y=29537
66500000000  X=86588    Y=9230
66600000000  X=145657    Y=43950
66623095107     done !
The orbit lengths are the same, it just goes through different points.
This proves that the "quiescent value" does not matter. I can stick to 0, any other value would be more complex to handle and wouldn't change the efficiency.
