DONKEY KONG JR. TABLE TOP REVIVAL (CJ-71)
Replacing a dead LCD on a 1983 Nintendo Game & Watch with an ILI9488 TFT, driven by an RP2040 — fully playable in the original shell.
Public Chat
My CJ-71 Table Top had a completely dead LCD — liquid crystals leaked, display unusable. Everything else still worked: SM511 MCU, piezo, joystick, buttons.
Rather than shelving it, I replaced the screen with an ILI9488 480×320 TFT driven by a Raspberry Pi Pico (RP2040), reimplemented the full game logic in C, and kept the original piezo audio — all inside the original shell, powered by the original 2× LR14 C-cell batteries.
My Nintendo Game & Watch Donkey Kong Jr. Table Top (CJ-71, 1983) had a completely dead LCD.
The liquid crystals had leaked, leaving a foggy, unusable display. The original Sharp SM511 MCU,
the piezo buzzer, the joystick and buttons — everything still worked. Only the screen was gone.
Rather than let it collect dust, I decided to bring it back to life — fully playable, in its
original shell, powered by its original C-cell batteries.
Goals / Constraints:
- Preserve the original shell, controls, and battery compartment
- Replace the dead LCD with a modern color TFT display
- Reimplement the full game logic faithfully
- Keep audio working via the original piezo buzzer
- Power everything from the original 2× LR14 C-cell batteries
Video
LCD crystal leaking
JPEG Image - 324.01 kB - 06/03/2026 at 15:36
Preview
LCD crystal leaking
JPEG Image - 142.85 kB - 06/03/2026 at 15:36
Preview
  • Dual-core architecture & multi-target build
    Kalice6 days ago 0 comments
    Dual-Core Architecture
    Cross-core communication uses volatile flags — no mutex overhead needed for this use case.
    • Core 0 — Game logic & display
      • XOR sprite rendering
      • DMA double buffering
      • Deferred flush (union bounding box)
      • Clock / alarm state machine
      • Input handling
    • Core 1 — Audio engine
      • Square wave generation on GP8
      • Drift-free timing
      • Melody + SFX queue
      • All code runs from RAM
    Software Versions
    Three build targets share the same game logic core:
    • Pico (Pico SDK )
    • MS-DOS (Watcom C 10.6)
    • Linux/Windows (GCC, SDL 1.2)
  • Reverse engineering the SM511 game logic
    • Game Logic
    I reversed engineered the game logic and reimplemented the full game state machine in C:
    - Player movement
    - Enemy spawning patterns (Game A and Game B)
    - Score and miss counter
    - Game over logic
    - Built-in clock and alarm
    • Graphics Pipeline
    The original CJ-71 uses a color filter overlay on a monochrome LCD. Each sprite is a fixed
    segment. To reproduce this on a TFT:
    - Sprites extracted from MAME artwork assets, converted to **RGB332** (1 byte/pixel) stored in flash
    - Transparent pixels use `0x00` as sentinel
    - Scenery background (471×238) centered on 480×320 display
    - XOR blitting over scenery, deferred flush with union bounding box
    - DMA double buffering for tear-free rendering
    A Python asset pipeline (`gen_sprites.py`) handles extraction, color conversion, and C header generation.
    • Audio
    The SM511 melody ROM (256 bytes) was extracted from MAME. Rather than emulating the SM511
    audio engine at runtime, I decoded the melody ROM offline into a table of `(freq_hz, duration_ms)`
    note pairs — full audio fidelity with no runtime SM511 dependency.
    On the Pico, **Core1** is dedicated to audio, generating square waves on GP8 via
    `busy_wait_until()` for drift-free timing. All audio code runs from RAM to avoid flash latency.
    The original CJ-71 audio circuit uses a PNP transistor (C458) in a negative-supply design to
    drive the piezo. On the Pico, a direct GPIO connection proved sufficient — the piezo pressed
    against the original plastic shell acts as a natural resonator and amplifier.
  • Hardware overview & power design
    •  Hardware
      • MCU : Raspberry Pi Pico (RP2040)
      • Display : ILI9488 480×320 SPI TFT (3.5")
      • Audio : Original CJ-71 piezo buzzer, GPIO driven
      • Power : 2× LR14 → XL6019 boost converter → 5V → Pico VBUS
      • SPI : SPI0 at 40MHz, 18-bit color
      • Consumption : ~55mA at 5V · ~70h estimated battery life
    The ILI9488 fits almost perfectly behind the original CJ-71 screen bezel.
    • Power
      • The original CJ-71 ran on 2× LR14 C-cell batteries (~3V). An XL6019 boost converter steps this up to stable 5V for the Pico VBUS.
View all 3 project logs
