UWB+GPS Converged Equipment
richardRichard wrote 04/18/2021 at 13:16 • • 2 min read • Like
Product features: support Beidou differential positioning and UWB positioning, automatic switching between indoor and outdoor high-precision positioning, positioning accuracy up to 2 cm outdoors, up to 10 cm indoor positioning accuracy, IP67 protection level, industrial-grade design.
Product parameter
Device model
HXZK-URT
Charging voltage
DC5V/1A
Indicators
4, 1 RTK indicator, 1 power indicator, 1 4G signal indicator , 1 UWB indicator light
Output power
-24dBmM/MHz
Life time (UWB mode)
>2 months
Life time (differential mode)
>10 hours
Charging port
Magnetic charging
battery
3000mAh
UWB working frequency band
3.75-4.25GHz
UWB refresh rate
1-100HZ
G refresh frequency
1-20 HZ
Satellite system
北斗+GPS
Differential accuracy
Plane accuracy:±(30 + 1×10-6×D)   mm   Elevation accuracy:±(50+ 1×10-6×D) mm
Channel bandwidth
500MHz
UWB antenna
Built-in omnidirectional antenna
GPS antenna
External spiral rod antenna
UWB Location Algorithm
support TOF/TDOA/RTK
UWB positioning accuracy
10Cm (unobstructed)
UWBCommunication distance
>300m
Size
57.5x85x59.5
weight / g
300
Operating temperature
-20℃~65℃
Working humidity
0%~90% No condensation
Protection level
IP67
Dormant
Smart sleep
ROHS
compatible
SOS alarm
support
Low battery warning
support
Automatic sleep and wake
support
Like
