CoreXY Mechanism
shane-hooperShane Hooper wrote 04/25/2021 at 14:35 • • 2 min read • Like
CoreXY Mechanism
CoreXY Mechanism
CoreXY Mechanism
CoreXY Kinematics
The corexy parallel kinematics mean's that the motors are the largest source of inertia within the system, and are stationary. This means rapid acceleration because the two stepper motors provide a means of moving both axes independently or simultaneously. The major benefit of the design is that the motors remain in a static position.
The corexy kinematics is a complex motion system where X or Y motors move together or opposite of each other to move the carriage from left to right or towards or away . If you were to move just one motor you would see the print head move diagonal.. If the two motors move opposite of each other the print head will move along the X-axis, If the two motors move in the same direction the carriage will move along the Y-axis.
Belt Path
A printer’s motors can be offset at different heights so that the belt routing runs a straight belt path and doesn't have to be twisted. But this belt routing path would also mean that on one side of the gantry the belt would have the teeth on the side of the idler wheel which wouldn’t run as smooth and could lead to artifacts within printed parts.
Motor Movement
Also See:
SolidCore CoreXY on Hackaday
CoreXY Mechanism
Like
