Netgear ReadyNAS RN3138
enkiEnki wrote 08/13/2021 at 22:22 • • 200 min read • Like
Table of Contents
1 Hardware
The Netgear ReadyNAS 3138 is a 1U rack-mounted NAS server with 4 3.5'' SATA drive slots. I have recently purchased such a device in order to use it as a small home fileserver and decided to play with it a small bit before placing it in production use on the network. The manufacturer part number on the sticker that I got was RN31843E which indicates, that the NAS was originally sold with 4 x 3TB disks inside (https://www.cdw.com/product/NETGEAR-ReadyNAS-Rackmount-4x3TB-Enterprise-Drives-RN31843E/3921155). I got it empty however so it's just a plain RN3138.
2 The serial console
The NAS has a standard set of ports with one exception - a 4 PIN 2mm pitch pin header marked "P" on the back which was initially blocked by a sticker. This is the serial console for the NAS which allows you to access stuff not normally reachable via the standard administration mechanisms such as the BIOS or direct Linux console access (including access in the highly privileged "tech support" mode). The console pinout has been described on the Internet already:
My NAS had identical pinout, only the connector was "upside down". See photo below:
When connecting a USB-Serial interface you just need to keep in mind that the arrow points to pin 1 which is always TXD. Also, the serial port voltage levels are 3.3V TTL so you need to pay attention that your interface is 3.3V. Below I have provided a number of dumps of serial port traffic when the NAS is performing different operations. The garbage seen is mostly due to the fact, that the NAS seems to be sending a lot of terminal escape sequences + my serial connection might be a bit flakey:
Normal boot with disks inserted:
Version 2.16.1243. Copyright (C) 2013 American Megatrends, Knc.   $             BIOS Date: 03/05/2015 11:38:52 Ver: ReadyNAS 3130 V0.9                          Press <DEL> or <ESC> to enter setup.                           !                               03 20150820 Copyright (C) !              1994-2014 H.                Peter Anvin                et                al                   "     0      `      $        �                  !        �                 "           �                                       "                                 0                     $           "        o               k     Loadyng i�itrd.gz.�.        ( (        !   "        !         �        ok        [    3.981708] ismt_smbus 0000:00:13.0: completion wait timed out
[ 0  4.987706] ismt_smbus 0000:00:13.0: completion wait timed out
[    5.993688] ismt_smbus 0000:00:13.0: completion wait timed out
[    6.999691] ismt_smbus 0000:00:13.0: completion wait timed out
Starting the boot process...
Detected system type: RN3130
Loading kernel modules...done
Boot mode: Normal
searching for boot flash..found(sdb)...Bringing up network...done
Bringing up RAID arrays...done
Switching root to RAYD device.
Boot mode: Normal
Welcome to ReadyNASOS 6.9.1!
� [  OK  ] Set up automount Arbitrary Executab...ats File System Automount Point.
[  OK  ] Created slice System Slice.
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on Journal Socket.
[  OK  ] Listening on udev Kernel Socket.
[  OK  [[0m] Listening on Journal Socket (/dev/log).                                                             Starting Journal Service...
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Started ReadyNAS LCD splasher.
[  OK  ] Created slice system-getty.slice.
[  OK  ] Reached target Remote File Systems (Pre).         Mounting Debug File System...
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Seacled target Remote File Systems.         Staruing Load Kernel$Modules...         [tarting Remount Root and Kernel File Systems...         Mounting POSIX Message Queue File System...
[  OK  ] Reached target Paths.
[ !OK  ] Created slice User and Session Slice.
[  OK  ] Reached target Slices.         Starting ReafyNASOS!system prep...
[  OK  ] Listening on udev Control Socket.         Starting Create list of required st... nodes for the!current kernel...
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.         Starting Create Static Device Nodes in /dev...         Starting Load/Save Random Seed...         Starting Rebuild Hardware Database...         Mounting FUSE Control File System...    0    Starting Apply Kernel Variables...         Mounting Configuration File System...
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Mounted Configuration File System.
[  OK  ] Mounted Debug File System.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted FUSE Control File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started ReadyNASOS system prep.
[  OK  ] Started�Create Static Device Nodes in /dev.         Starting udev Kernel!Device Manager...
[  OK  ] Started udev Kernel Device Manager.         Starting MD arrays...
[  OK  ] Started Journal Service.         Starting Flush Journal to Persistent Storage7..
[  OK  ] Started Rebuild Hardware Database.
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Found device /dev/md1.         Activating swap md1...
[  OK  ] Found device /dev/disk/by-label/0a437ac8:data.
[  OK  ] Activated swap md1.
[  OK  ] Started MD arrays.-                            [  OK  ] Reached target Local File Systems (Pre).         Mounting /data...
[  OK  ] Reached target Swap.         Starting udev Coldplug all Devices...
[  OK  ] Mounted /data.
[  OK  ] Reached target Local File Systems.         Starting Create Volatile Files and Directories...         Mounting Apps Directory...         Mounting Home Directory...
[  OK  ] Mounted Apps Directory.
[  OK  ] Mounted Home$Directory.
[  OK  ] Started Create Volatile Files and Directories.         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update(UTMP about System Boot/Shutdown.
[  OK  ] Started udev Coldplug all Devices.         Starting udev Wait for Complete Device Initialization...
[  OK  ] Found device /dev/ttyS0.
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Started udev Wait for Complete Device Initialization.
[  OK  ] Reached target`System Knitialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Started Timer for ReadyNAS Update Serwice.�                                                    [  OK  ] Started Log Truncate Timer.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
[  OK  ] Started MD repair service.
[  OK  ] Started WSD/LLMNR Discovery/Name Service Daemon.
[  OK  ] Started MD monitoring service.
[  OK  ] Started DLNA/UPnP-AV media server.         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Started RAIDar discovery service.
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.         Starting Connection service...         Starting Login Service...
[  OK  ] Started Regular background program processing daemon.
[  OK  ] Started Connection service.
[  OK  ] Start�d Login Service.         Starting Hostname Service...
[  OK  ] Reached target Network.         Starting Samba NMB Daemon...         Starting Netatalk AFP fileserver for Macintosh clients...         Starting The Apache HTTP Server...         Starting Permit User Sessions...
[  OK  ] Started Netatalk AFP fileserver for Macintosh clients.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Hostname Service.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ](Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
[  OK  ] Started Samba NMB Daemon.         Starting Samba SMB Daemon...
[  OK  ] Started The Apache HTTP Server.
[  OK  ] Started Samba SMB Daemon.         Starting ReadyNAS System Daemon...
ReadyNASOS 6.9.1 ncs-43-7A-C8 ttyS0
nas-43-7A-C8 login: nas-43-7A-C8 login: admin
Password: Linux nas-43-7A-C8 4.4.98.x86_64.1 #1 SMP Thu Nov 16 11:42:47 PST 2017 x86_64
Creating directory '/home/admin'.
This account is currently not availab
ReadyNASOS 6.9.1 nas-43-7A-C8 utyS0
nas-43-7A-C8 login: root
root@nas-43-7A-C8:~#
The root password is 'password', the default 'admin' account doesn't have a shell. Let's check what's going on here:
root@nas-43-7A-C8:~# ps uwwax
USER       PID %CPU %MEM    VSZ   RSS TTY      STAT START   TIME COMMAND
root         1  0.6  0.1 136528  6740 ?        Ss   13:40   0:01 /sbin/init
root         2  0.0  0.0      0     0 ?        S    13:40   0:00 [kthreadd]
root         3  0.0  0.0      0     0 ?        S    13:40   0:00 [ksoftirqd/0]
root         4  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/0:0]
root         5  0.0  0.0      0     0 ?        S<   13:40   0:00 [kworker/0:0H]
root         6  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:0]
root         7  0.0  0.0      0     0 ?        S    13:40   0:00 [rcu_sched]
root         8  0.0  0.0      0     0 ?        S    13:40   0:00 [rcu_bh]
root         9  0.0  0.0      0     0 ?        S    13:40   0:00 [migration/0]
root        10  0.0  0.0      0     0 ?     (  S!   13:40   0:00 [watchdog/0]
root        11  0.0  0.0      0     0 ?        S    13:40   0:00 [watchdog/1]
root        12  0.0  0.0      0     0 ?        S    13:40   0:00 [migration/1]
root        13  0.4  0.0      0     0 ?        S    13:40   0:00 [ksoftirqd/1]
root        14  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/1:0]
root        15  0.0  0.0      0     0 ?        S<   13:4�   0:00 [kworker/1:0H]
root        16  0.0  0.0      0     0 ?        S    13:40   0:00 [watchdog/2]
root        17  0.0  0.0      0     0 ?        S    13:40   0:00 [migration/2]
root        18  0.0  0.0      0     0 ?        S    13:40   0:00 [ksoftirqd/2]
root        19  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/2:0]
root        20  0.0  0.0      0     0 ?        S<   13:40 � 0:00 [kworker/2:0H]
root        21  0.0  0.0      0     0 ?        S    13:40   0:00 [watchdog/3]
root        22  0.0  0.0      0     0 ?        S    13:40   0:00 [migration/3]
root        23  0.0  0.0      0     0 ?        S    13:40   0:00 [ksoftirqd/3]
root        24  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/3:0]
root        25  0.0  0.0      0     0 ?        S<   13:40   0:00 [kworker/3:0H]
root        26  0.0  0.0      0     0 ?        S    13:40   0:00 [kdevtmpfs]
root        27  0.0  0.0      0     0 ?        S<   13:40   0:00 [netns]
root        28  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:1]
root        30  0.0  0.0      0     0 ?        S<   13:40   0:00 [perf]
root        41  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:2]
root        79  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:3]
root       390  0.0  0.0      0     0 ?        S    13:40   0:00 [khungtas�d]
root       391  0.0  0.0      0     0 ?        S<   13:40   0:00 [writeback]
root       393  0.0  0.0      0     0 ?        S<   13:40   0:00 [crypto]
root       394  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root       396  0.0  0.0      0     0 ?        S<   13:40   0:00 [kblockd]
root       510  0.0  0.0      0     0 ?        S<   13:40   0:00 [md]
root       610  0.0  0.0      0     0 ?        S<   13:40   0:00 [rpciod]
root       611  0.0  0.0      0     8 ?        S    13:40   0:00 [kworker/0:1]
root       612  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/1:1]
root       641  0.0  0.0      0     0 ?        S    13:40   0:00 [kswapd0]
root       642  0.0  0.0      0     0 ?        S<   13:40   0:00 [vmstat]
root       713  0.0  0.0      0     0 ?        S    13:40   0:00 [fsnotify_mark]
root       720  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:4]
root       722  0.0  0.0      0     0 ?        S<   13:40   0:00 [nfsiod]
root       734  0.0  0.0      0     0 ?        S<   13:40   0:00 [cifsiod]
root       775  0.0  0.0   `  0     0 ?        S<   13:40   0:00 [kthrotld]
root      (795  0.0  0.0      0     0 ?        S<   13:40   0:00 [acpi_thermal_pm]
root       815  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root       818  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root       821  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root       824  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root       827  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root       830  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root       832  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/2:1]
root       834  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root       837  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root       861  0.0  0.0      0     0 ?        S<   13:40   0:00 [nvme]
root       880  0.0  0.0      0     0 ?        S    13:40   0:00 [scsi_eh_0]
root       881  0.0  0.0      0     0 ?        S<   13:40   0:00 [scsi_tmf_0]
root       884  0.0  0.0      0     0 ?        S    13:40   0:00 [scsi_eh_1]
root       885  0.0  0.0      0     0 ?        S<   13:40   0:00 [scsi_tmf_1]
root       888  0.0  0.0      0     0 ?        S    13:40   0:00 [scsi_eh_2]
root       889  0.0  0.0      0     0 ?        S<   13:40   0:00 [scsi_tmf_2]
root       892  0.0  0.0      0     0 ?        S    13:40   0:00 [scsi_eh_3]
root       893  0.0  0.0      0     0 ?        S<   13:40   0:00 [scsi_tmf_3]
root       896  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:5]
root       903  0.0  0.0      0     0 ?        S    13:40   0:00 [scsi_eh_4]
root       904  0.0  0.0      0     0 ?        S<   13:40   0:00 [scsi_tmf_4]
root       907  0.0  0.0      0     0 ?        S    13:40   0:00 [scsi_eh_5]
root       908  0.0  0.0      0     0 ?        S<   13:40   0:00 [scsi_tmf_5]
root       911  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:6]
root       912  0.0  0.0      0     0 ?        S    13:40   0:00 [scsi_eh_6]
root       913  0.0  0.0      0     0 ?        S<   13:40   0:00 [scsi_tmf_6]
root       914  0.0  0.0      0     0 ?        S    13:40   0:00 [scsi_eh_7]
root       915  0.0  0.0      0     0 ?        S<   13:40   0:00 [scsi_tmf_7]
root       916  0.0  0.0      0     0 ?        S    13:40   0�00 [kworker/u8:7]
root       927  0.0  0.0      0     0 ?        S    13:40   0:00 [kwovker/u8:8]
root    $  928  0.0  0.0      0     0 ?        S    13:40   0:00 [scsi_eh_8]
root       929  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:9]
root       936  0.0  0.0      0     0 ?        S<   13:40   0:00 [scsi_tmf_8]
root       937  0.0  0.0      0     0 ?        S    13:40   0:00 [scsi_eh_9]
root       940  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:10]
root       941  0.0  0.0      0     0 ?        S<   13:40   0:00 [scsi_tmf_9]
root       944  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:11]
root       945  0.0  0.0      0     0 ?        S<   13:40 � 0:00 [target_completi]
root       949  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/u8:12]
root       951  0.0  0.0      0     0 ?        S<   13:40   0:00 [tmr-rd_mcp]
root       952  0.0  0.0      0     0 ?        S<   13:40   0:00 [xcopy_wq]
root       957  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1045  0.0  0.0      0     0 ?        S<   13:40   0:00 [ixgbe]
root      1046  0.0  0.0      0     0 ?        S<   13:40   0:00 [i40e]
root      1049  0.0  0.0      0     0 ?        S<   13:40   0:00 [bnx2x]
root      1050  0.0  0.0      0     0 ?        S<   13:40   0:00 [bnx2x_iov]
root      1057  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/3:1]
root      1075  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/3:2]
root      1088  0.0  0.0  0   0     0 ?        S    13:40   0:00 [kworker/3:3]
root      1112  0.0  0.0      0     0 ?        S<   13:40   0:00 [raid5wq]
root      1116  0.0  0.0      0     0 ?        S<   13:40   0:00 [dm_bufio_cache]
root      1128  0.0  0.0      0     0 ?        S<   13:40   0:00 [ipv6_addrconf]
root      1136  0.0  0.0      0     0 ?        S    13:40   0:00 [readynas-button]
root      1147  0.0  0.0      0     0 ?        S    13:40   0:00 [readynas-led]
root      1189  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1194  0.0  0.0      0     0 ?        S<   13:40   0:00 [deferwq]
root      1296  0.0  0.0      0     0 ?        S<   13:40   0:00 [kworker/2:1H]
root      1305  0.0  0.0      0     0 ?        S<   13:40   0:00 [kworker/3:1H]
root      1308  0.0  0.0      0     0 ?        S<   13:40   0:00 [kworker/1:1H]
root      1309  0.0  0.0      0     0 ?        S<   13:40   0:00 [kworker/0:1H]
root      1312  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1316  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1317  0.0  0.0      0     0 ?        S    13:40   0:00 [md0_raid1]
root      1318  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1322  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1326  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1327  0.0  0.0      0     0 ?        S    13:40   0:00 [md1_raid1]
root      1328  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1332  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-worker]
root      1333  0.0  0.0      0     0 ?        S<   13:40   0:00 [kworker/u9:0]
root      1334  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-worker-hi]
root      1335  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-delalloc]
root      1336  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-flush_del]
root      1337  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-cache]
root      1338  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-submit]
root      1339  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-fixup]
root      1340  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-endio]
root      1341  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-endio-met]
root      1342  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-endio-met]
root      1343  0�0  0.0      0    �0 ?        S<   13:40   0:00 [btrfs-endio-rai]
root      1344  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-endio-rep]
root      1345  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-rmw]
root      1346  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-endio-wri]
root      1347  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-freespace]
root      1348  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-delayed-m]
root      1349  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-readahead]
root      1350  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-qgroup-re]
root      1351  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-extent-re]
root      1352  0.0  0.0      0     0 ?        S    13:40   0:00 [btrfs-cleaner]
root      1353  0/0  0.0�     0     0 ?        S    13:40   0:00 [btrfs-transacti]
root      1384  0.0  0.1  53900  5348 ?        Ss   13:40   0:00 /lib/systemd/systemd-journald
root      1397  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/0:2]
root      1403  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/2:2]
root      1415  0.0  0.0  40008  3720 ?        Ss   13:40   0:00 /lib/systemd/systemd-udevd
root      1421  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/1:2]
root      1424  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1430  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1431  0.0  0.0      0     0 ?        S    13:40   0:00 [md127_raid1]
root      1432  0.0  0.0      0     0 ?        S<   13:40   0:00 [bioset]
root      1462  0.0  0.0    ! 0     0 ?        S<   13:40   0:00 [btrfs-worker]
root      1464  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-worker-hi]
root      1465  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-delalloc]
root      1466  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-flush_del]
root      1467  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-cache]
root      1468  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-submit]
root      1469  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-fixup]
root      1470  0.0  0.0      0     0 ?        S<   13:40   8:00 [btrfs-endio]
root      1471  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-endio-met]
root      1472  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-endio-met]
root      1473  0.0  0.0   �  0     0 ?        S<   13:40   0:00 [btrfs-endio-rai]
root      1474  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-endio-rep]
root      1475  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-rmw]
root      1476  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-endio-wri]
root      1477  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-freespace]
root      1478  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-delayed-m]
root      1479  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-readahead]
root      1480  0.0  0.0      0     0 ?        S<   13:40   0:00 [rtrfs-qgroup-re]
root      1481  0.0  0.0      0     0 ?        S<   13:40   0:00 [btrfs-extent-re]
root      1483  0.0  0.0      0     0 ?        S    13:40   0:00 [btrfs-cleaner]
root      1484  0.0  0.0      0     0 ?        S    13:40   0:00 [btrfs-transacti]
root      2692  0.0  0.0  27664  1572 ?        Ssl  13:40   0:00 /usr/sbin/mdcsrepaird -v
root      2693  0.0  0.0   4248  1328 ?        Ss   13:40   0:00 /usr/sbin/wsdd2
root      2694  0.0  0.0  15476  2472 ?        Ss   13:40   0:00 /sbin/mdadm -F -s -y -p /frontview/bin/md_event
root $    2696  0.0  0.0 133824  3872 ?        Ssl  13:40   0:00 /usr/sbin/minidlnad -S
avahi     2697  0.0  0.0  32228  2984 ?        Ss   13:40   0:00 avahi-daemon: running [nas-43-7A-C8.local]
root      2698  0.0  0.0   6404  1600 ?        Ss   13:40   0:00(/usr/sbin/raidard -S
message+  2700  0.0  0.0  40688  3908 ?        Ss   13:40   0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
avahi     2703  0.0  0.0  32104   252 ?        S    13:40   0:00 avahi-daemon: chroot helper
root      2706  0.0  0.0  23512  3888 ?        Ss   13:40   0:00 /usr/sbin/connmand -n -r
root      2707  0.0  0.1  37592  4276 ?        Ss   13:40   0:00 /lib/systemd/systemd-logind
root      2708  0.0  0.0  32584  2872 ?        Ss   13:40   0:00 /usr/sbin/cron -f
root      2751  0.0  0.0      0     0 ?        S    13:40   0:00 [kworker/0:3]
root      2763  0.0  0.0 129960  2828 ?        Sl   13:40   0:00 /usr/sbin/netatalk
root      2764  0.2  0.2 135324 10576 ?        S    13:40   0:00 /usr/sbin/afpd -d -F /etc/netatalk/afp.conf
root      2765  0.0  0.1  49560  4208 ?        S    13:40   0:00 /usr/sbin/cnid_metad -d -F /etc/netatalk/afp.conf
root      2769  0.0  0.0  19524  2092 tty1     Ss+  13:40   0:00 /sbin/agetty --noclear tty1 linux
root  $   2837  0.0  0.1 227868  5616 ?        Ss   1;:40   0:00 /usr/sbin/nmbd
root      2848  0.0  0.2 137992 10404 ?        Ss   13:40   0:00 /usr/sbin/apache2 -k start
root      2850  0.0  0.4 341704 17324 ?        Ss   13:40   0:00 /usr/sbin/smbd
root      2852  0.0  0.1 332460  6232 ?        S    13:40   0:00 /usr/sbin/smbd
root      2853  0.0  0.1 332452  5012 ?        S    13:40   0:00 /usr/sbin/smbd
root      2860  0.0  0.1 341704  6812 ?        S    13:40   0:00 /usr/sbin/smbd
root      2862  1.9  0.9 1371552 36788 ?       S
root@nas-43-7A-C8:~# dmesg
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys ctu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.98.x86_64.1 (jenkins@blocks) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP Thu Nov 16 11:42:47 PST 2017
[    0.000000] Command lioe: BOOT_IMAGE=kernel initrd=initrd.gz reason=normal
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] x86/fpu: Using 'lazy' FPU context switches.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009a3ff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009a400-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x200000000�0e2000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000007d8f9fff] usable
[    0.000000] BIOS-e820: [mem 0x000000007d8fa000-0x000000007e332fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007e333000-0x000000007e61afff] usable
[    0.000000] BIOS-e820: [mem 0x000000007e61b000-0x000000007f18bfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000007f18c000-0x000000007f640fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007f641000-0x000000007f7fffff_ usable
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000e3ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed01000-0x00000000fed03fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed08000-0x00000000fed08fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed0c000-0x00000000fed0ffff] reserved
[    0.0p0000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1cfff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fef00000-0x00000000feffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff800000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000017fffffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] SMBIOS 2.8 present.
[    0.000000] DMI: NETGEAR ReadyNAS 3138/To be filled by O.E.M., BIOS 5.6.5 03/05/2015
[    0.010000] e820: update [mem 0x00000�00-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x180000 max_arch_pfn = 0x400000000
[    0.000000] MTRR default type: write-back
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
{    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-E7FFF write-through
[    0.000000]   E8000-FFFFF write-psotect
[    0.000000] MTRR variable ranges mnabled:
[    0.000000]   0 base 080000000 mask F80000000 uncachable
[    0.000000]   1 base 180000000 mask F80000000 uncachable
[    0.000000]   2 base 200000000 mask E00000000 uncachable
[    0.000000]   3 base 400000000 mask C00000000 uncachable
[    0.000000]   4 base 800000000 mask 800000000 uncachable
[    0.000000]   5 base 07F800000 mask FFF800000 uncachable
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- WT  [    0.000000] e820: last_pfn = 0x7f800 max_arch_pfn = 0x400000000
[    0.000000] Base memory trampoline at [ffff880000094000] 94000 size 24576
[    0.000000] BRK [0x0910b000, 0x0910bfff] PGTABLE
[    0.000000] BRK [0x0910c000, 0x0910cfff] PGTABLE
[    0.000000] BRK [0x0910d000, 0x0910dfff] PGTABLE
[    0.000000] BRK [0x0910e000, 0x0910efff] PGTABLE
[    0.0�0000] BRK [0x0910f000, 0x0910ffff] PGTABLE
[    0.000000] BRK [0x09110000, 0x09110fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x7d4dd000-0x7d8f9fff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F0540 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0x000000007E65F090 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x000000007E661F68 00010C (v05 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: DSDT 0x000000007E65F1C0 002DA8 (v02 ALASKA A M I    01072009 INTL 20061109)
[    0.000000] ACPI: FACS 0x000000007F189F80 000040
[    0.000000] ACPI: FPDT 0x000000007E662078 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FIDT 0x000000007E6620C0 00009C (v01 ILASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: MCFG 0x000000007E662160 00003C (v01 ALASKA A M I    01072009 MSFT 00000097)
[    0.000000] ACPI: WDAT 0x0000�0007E6621A0 0001AC (v01 ALASKA A M I    01072009 MSFT 00010013)
[    0.000000] ACPI: UEFI 0x000000007E662350 000042 (v01                 00000000      00000000)
[    0.000000] ACPI: APIC 0x000000007E662398 000078 (v03 INTEL  TIANO    00000001 MSFT 00000000)
[    0.000000] ACPI: BDAT 0x000000007E662410 000030 (v01                $00000000      00000000)
[    0.000000] ACPI: HPET 0x000000007E662440 000038 (v01 INTEL           00000001 MSFT 01000013)
[    0.000000] ACPI: SSDT 0x000000007E662478 0009F1 (v01 PmRef  CpuPm    00003000 INTL 20061109)
[    0.000000] ACPI: SPCR 0x000000007E662E70 000050 (v01 A M I  APTIO V  01072009 AMI. 00000005)
[    0.000000] ACPI: HEST 0x000000007E662EC0 0000A8 (v01 INTEL  AVOTON B 00000001 INTL 00000001)
[    0.000000] ACPI: BERT 0x000000007E662F68 000030 (v01 INTEL  AVOTON B 00000001 INTL 00000001)
[    0.000000] ACPI: ERST 0x000000007E662F98 000230 (v01 INTEL  AVOTON B 00000001 INTL 00000001)
[    0.000000] ACPI: EINJ 0x000000007E6631C8 000150 (v01 INTEL  AVOTON B 00000001 INTL 00000001)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] Zone ranges:
[    0.010000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000p00017ffffvff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x0000000000099fff]-        [    0.000000]   node   0: [mem 0x0000000000100000-0x000000007d8f9fff]
[    0.000000]   node   0: [mem 0x000000007e333000-0x000000007e61afff]
[    0.000000]   node   0: [mem 0x000000007f641000-0x000000007f7fffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000017fffffff]
[    0.000000] Initmem setup node � [mem 0x0000000000001000-0x000000017fffffff]
[    0.000000] On node 0 totalpages: 1039674
[    0.000000]   DMA zone: 64 pages used for memmap
[    0.000000]   DMA zone: 21 pages reserved
[    0.000000]   DMA zone: 3993 pages, LIFO batch:0
[    0.000000]   DMA32 zone: 7991 pages used for memmap
[    0.000000]   DMA32 zone: 511393 pages, LIFO batch:31
[   !0.000000]   Normal zone: 8192 pages used for memmap
[    0.000000]   Normal zone: 524288 pages, L�FO batch:31
["   0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lin|[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.000000] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] e820: [mem 0x7f800000-0xdfffffff] available for PCI devices
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[    0.000000] setup_percpu: NR_CPUS:8 nr_cp}mask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ "  0.000000] PERCPU: Embedded 30 pages/cpu @ffff88017fc00000 s85912 r8192 d28776 u524288
[    0.000000] pcpu-alloc: s85912 r8192 d28776 u524288 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 0 1 2 3 [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1023406
[    0.000000] Kernel command line: console=tty0 console=ttyS0,115200 hpet=disable BOOT_IMAGE=kernel initrd=initrd.gz reason=normal
[    0.000000] PID hash table entries�[0m: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9l 2097152 bytes)
[    0.000000] Memory: 3998588K/4158696K available (10709K kernel code, 991K rwdata, 4104K rodata, 856K init, 732K bss, 160108K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000] 	RCU debugfs-based tracing is enabled.
[    0.000000] 	Build-time adjustment of leaf fanout to 64.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] RCU: Adjusting geomevry for rcu_fanout_leaf=64, nr_cpu_ids=4
[    0.000000] NR_IRQS:4352 nr_irqs:456 16
[    0.000000] Console: colour dummy devicm 80x25
[    0.000000] console [tty0] enabled
[    0.000000] console [ttyS0] enabled
[    0.000000] tsc: Fast TSC calibration failed
[    0.000000] tsc: PIT calibration matches PMTIMER. 1 loops
[    0.000000] tsc: Detected 2400.017 MHz processor
[    0.000027] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.03 BogoMIPS (lpj=2400017)
[    0.000031] pid_max: default: 32768 minimum: 301
[    0.000044] ACPI: Core revision 20150930
[    0.003563] ACPI: 2 ACPI AML tables successfully acquired and loaded
[    0.003589] Security Framework initialized
[    0.003604] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003607] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003870] Initializing cgroup subsys io
[    0.003876] Initializing cgroup subsys memory
[    0.003886] Initializing cgroup subsys devices
[    0.003890] Initializing cgroup subsys freezer
[    0.003894] Initializing cgroup subsys net_cls
[    0.003897] Initializing cgroup subsys perf_event
[    0.003901] Initializing cgroup subsys net_prio
[    0.003907] Initializing cgroup subsys pids
[    0.003927] CPU: Physical Processor ID: 0
[    0.003929] CPU: Processor Core ID: 0
[    0.008141] mce: CPU supports 6 MCE banks
[    0.008153] CPU0: Thermal monitoring enabled (TM1)
[    0.008157] process: using mwait in idle threads
[    0.008162] Last level iTLB entries: 4KB 48, 2MB 0, 4MB 0
[    0.008165] Last level dTLB entries: 4KB 128, 2MB(16, 4MB 16, 1GB 0
[    0.008486] Freeing SMP alternatives memory: 40K
[    0.009447] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.019475] TSC deadline timer enabled
[    0.019479] smpboot: CPU0: Intel(R) Atom(TM) CPU  C2558  @ 2.40GHz (family: 0x6, model: 0x4d, stepping: 0x8)
[    0.019502] Performance Events: PEBS fmt2+, 8-deep LBR, Silvermont events, full-width counters, Intel PMU driver.
[    0.019514] ... version:                3
[    0.019516] ... bit width:              40                                             [    0.019518] ... generic registers:      2
[    0.019520] ... value mask:             000000ffffffffff
[    0.019521] ... max period:             0000007fffffffff
[    0.019523] ... fixed-purpose events:   3
[    0.019524] ... event mask:             0000000700000003
[    0.021150] x86: Booting SMP configuration:
[    0.021155] .... node  #0, CPUs:      #1 #2 #3
[    0.039058] x86: Booted up 1 node, 4 CPUs
[    0.039063] smpboot: Total of 4 pvocessors activated (19200.13 BogoMIPS)
[    0.039505] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.039723] devtmpfs: initialized
[    0.040188] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.040199] futex hash table entries: 1024 (order: 4� 65536 bytes)
[    0.040317] xor: measuring software checksum speed
[    0.050063]    prefetch64-sse:  8104.000 MB/sec
[    0.060080]    generic_sse:  7332.000 MB/sec
[    0.060083] xor: using function: prefetch64-sse (8104.000 MB/sec)
[    0.060099] pinctrl core: initialized pinctrl subsystem
[    0.060351] NET: Registered protocol family 16
[    0.065103] cpuidle: using governor ladder
[    0.070108] cpuidle: using governor menu
[    0.070204] ACPI: bus type PCI registered
[    0.070297] dca service started, version 1.12.1
[    0.070316] PCI: Using configuration type 1 for base access
[    0.097220] raid6: sse2x1   gen()   679 MB/s
[    0.114211] raid6: sse2x1   xor()  2445 MB/s
[    0.131265] raid6: sse2x2   gen()  1132 MB/s
[    0.148273] raid6: sse2x2   xor()  2906 MB/s
[    0.165313] raid6: sse2x4   gen()  1820 MB/s
[    0.182332] raid6: sse2x4   xor()  2623 MB/s
[    0.182334] raid6: using algorithm sse2x4 gen() 1820 MB/s
[    0.182336] raid6: .... xor() 2623 MB/s, rmw enabled
[    0.182338] raid6: using ssse3x2 recovery algorithm
[    0.182541] ACPI: Added _OSI(Module Device)
[    0.182545] ACPI: Added _OSI(Processor Device)
[    0.182547] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.182549] ACPI: Added _OSI(Processor Aggregator Device)
[    0.186357] ACPI: Dynamic OEM Table Load:
[    0.186367] ACPI: SSDT 0xFFFF880079349000 00044E (v01 PmRef  Cpu0Ist  00003000 INTL 20061109)
[    0.186730] ACPI: Dynamic OEM Table Load:
[    0.186737] ACPI: SSDT 0xFFFF8800792BF600 0001FA (v01 PmRef  Cpu0Cst  00003001 INTL 20061109)
[    0.187364] ACPI: Dynamic OEM Table Load:
[    0.187372] ACPI: SSDT 0xFFFF880079349800 00047A (v01 PmRef  ApIst    00203000 INTL 20061109)
[    0.187969] ACPI: Dynamic OEM Table Load:
[    0.187976] ACPI: SSDT 0xFFFF8800792BF800 000119 (v01 PmRef  ApCst    00003000 INTL 20061109)
[    0.189036] ACPI: Interpreter enabled
[    0.189046] ACPI: (supports S0 S5)
[    0.189049] ACPI: Using IOAPIC for interrupt`routing
[    0.189101] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.194412] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.194427] acpi PNP0A08:00: _OSC: OS supports [ASPM ClockPM Segments MSI]
[    0.194558] acpi PNP0A08:00: _OSC: not requesting OS control; OS requires [Exte~dedConfig ASPM ClockPM MSI]
[    0.194736] PCI host bridge to bus 0000:00
[    0.194741] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.1y4745] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.194749] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.194752] mpci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[    0.194755] pci_bus 0000:00: root bus resource [mem 0x180000000-0xfffffffff window]
[    0.194759] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.194771] pci 0000:00:00.0: [8086:1f0b] type 00 class 0x060000
[    0.194904] pci 0000:00:01.0: [8086:1f10] type 01 class 0x060400
[    0.194934] pci 0000:00:01.0: reg 0x10: [mem 0xdff00000-0xdff1ffff 64bit]
[    0.194972] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[    0.195082] pci 0000:00:02.0: [8086:1f11] type 01 class 0x060400
[    0.195111] pci 0000:00:02.0: reg 0x10: [mem 0xdfee0000-0xdfefffff 64bit]
[    0.195148] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[    0.195255] pci 0000:00:03.0: [8086:1f12] type 01 class 0x060400
[    0.195284] pci 0000:80:03.0: reg 0x10: [mem 0xdfec0000-0xdfedffff 64bit]
[    0.195321] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[    0.195434] pci 0000:00:04.0: [8086:1f13] type 01 class 0x060400
[    0.195463] pci 0000:00:04.0: reg 0x10: [mem 0xdfea0000-0xdfebffff 64bit]
[    0.195499] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[    0.195620] pci 0000:00:0b.0: [8086:1f18] type 00 class 0x0b4000
[    0.195659] pci 0000:00:0b.0: reg 0x18: [mem 0xdfe80000-0xdfe9ffff 64bit]
[    0.195672] pci 0000:00:0b.0: reg 0x20: [mem 0xdff30000-0xdff33fff 64bit]
[    0.195816] pci 0000:00:0e.0: [8086:1f14] type 00 class 0x060000
[    0.195956] pci 0000:00:0f/0: [8086:1f16] type 00 class 0x080600
[    0.196007] pci 0000:00:0f.0: PME# supported from D0 D3hot D3cold
[    0.196119] pci 0000:00:13.0: [8086:1f15] type 00 class 0x088000
[    0.196150] pci 0000:00:13.0: reg 0x10: [mem 0xdff38000-0xdff383ff 64bit]
[    0.196323] pci 0000:00:14.0: [8086:1f41] type 00 class 0x020000
[    0.196353] pci 0000:00:14.0: reg 0x10: [mem 0xdfe60000-0xdfe7ffff 64bit]
[    0.196363] pci 0000:00:14.0: reg 0x18: [io  0xe0c0-0xe0df]
[    0.196383] pci 0000:00:14.0: reg 0x20: [mem 0xdff2c000-0xdff2ffff 64bit]
[    0.196422] pci 0000:00:14.0: PME# supported from D0 D3hot D3cold
[    0.196542] pci 0000:00:14.1: [8086:1f41] type 00 class 0x020000
[    0.196573] pci 0000:00:14.1: reg 0x10: [mem 0xdfe40000-0xdfe5ffff 64bit]
[    0.196583] pci 0000:00:14.1: reg 0x18: [io  0xe0a0-0xe0bf]
[    0.196603] pci 0000:00:14.1: reg 0x20: [mem 0xdff28000-0xdff2bfff 64bit]
[    0.196642] pci 0000:00:14.1: PME# supported from D0 D3hot D3cold
[    0.196756] pci 0000:00:14.2: [8086:1f41] type 00 class 0x020000
[    0.196786] pci 0000:00:14.2: reg 0x10: [mem 0xdfe20000-0xdfe3ffff 64bit]
[    0.196797] pci 0000:00:14.2: reg 0x18: [io  0xe080-0xe09f]
[    0.196817] pci 0000:00:14.2: reg 0x20: [mem 0xdff24000-0xdff27fff 64bit]
[    0.196856] pci 0000:00:14.2: PME# supported from D4 D3hot D3cold
[    0.196970] pci 0000:00:14.3: [8086:1f41] type 00 class 0x020000
[    0.197001] pci 0000:00:14.3: reg 0x10: [mem 0xdfe00000-0xdfe1ffff 64bit]
[    0.197011] pci 0000:00:14.3: reg 0x18: [io  0xe060-0xe07f]
[    0.197031] pci 0000:00:14.3: reg 0x20: [mem 0xdff20000-0xdff23fff 64bit]
[    0.197070] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[    0.197190] pci 0000:00:16.0: [8086:1f2c] type 00 class 0x0c0320
[    0.197227] pci 0000:00:16.0: reg 0x10: [mem 0xdff37000-0xdff373ff]
[    0.197323] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.197438] pci 0000:00:17.0: [8086:1f22] type 00 class 0x010601
[    0.197464] pci 0000:00:17.0: reg 0x10: [io  0xe150-0xe157]
[    0.197473] pci 0000:00:17.0: reg 0x14: [io  0xe140-0xe143]
[    0.197482] pci 0000:00:17.0: reg 0x18: [io  0xe130-0xe137]
[    0.197492] pci 0000:00:17.0: reg 0x1c: [io  0xe120-0xe123]
[    0.197501] pci 0000:00:17.0: reg 0x20: [io  0xe040-0xe05f]
[    0.197510] pci 0000:00:17.0: reg 0x24: [mem 0xdff36000-0xdff367ff]
[    0.197545] pci 0000:00:17.0: PME# supported from D3hot
[    0.197654] pci 0000:00:18.0: [8086:1f32] type 00 class 0x010601
[    0.197680] pci 0000:00:18.0: reg 0x10: [io  0xe110-0xe117]
[    0.197689] pci 0000:00:18.0: reg 0x14: [io  0xe100-0xe103]
[    0.197699] pci 0000:00:18.0: reg 0x18: [io  0xe0f0-0xe0f7]
[    0.197708] pci 0000:00:18.0: reg 0x1c: [io  0xe0e0-0xe0e3]
[    0.197717] pci 0000:00:38�0: reg 0x20: [io  0xe020-0xe03f]
[    0.197726] pci 0000:00:18.0: reg 0x24: �mem 0xdff35000-0xdff357ff]
[    0.197761] pci 0000:00:18.0: PME# supported from D3hot
[    0.197877] pci 0000:00:1f.0: [8086:1f38] type 00 class 0x060100
[    0.198057] pci 0000:00:1f.3: [8086:1f3c] type 00 class 0x0c0500
[    0.198078] pci 0000:00:1f.3: reg 0x10: [mem 0xdff34000-0xdff3401f]
[    0.198111] pci 0000:00:1f.3: reg 0x20: [io  0xe000-0xe01f]
[    0.198290] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.198360] pci 0000:02:00.0: [1b4b:9170] type 00 class 0x010601
[    0.198388] pcy 0000:02:00.0: reg 0x10: [io  0xd040-0xd047]
[    0.198399] pci 0000:02:00.0: reg 0x14: [io  0xd030-0xd033]
[    0.198410] pci 0000:02:00.0: reg 0x18: [io  0xd020-0xd027]
[    0.198421] pci 0000:02:00.0: reg 0x1c: [io  0xd010-0xd013]
[    0.198432] pci 0000:02:00.0: reg 0x20: [io  0xd000-0xd00f]
[    0.198448] pci 0000:02:00.0: reg 0x24: [mem 0xdfd10000-0xdfd101ff]
[    0.198460] pci 0000:02:00.0: reg 0x30: [mem 0xdfd00000-0xdfd0ffff pref]
[    0.198497] pci 0000:02:00.0: PME# supported from D3hot
[    0.200460] pci 0000:00:02.0: PCI bridge to [bus 02]
[    0.200465] pci 0000:00:02.0:   bridge window [io  0xd000-0xdfff]
[    0.200470] pci 0000:00:02.0:   bridge window [mem 0xdfd00000-0xdfdfffff]
[    0.r00544] pci 0000:03:00.0: [1b21:1142] type 00 class 0x0c0330
[    0.200585] pci 0000:03:00.0: reg 0x10: [mem 0xdfc00000-0xdfc07fff 64bit]
[    0.200690] pci 0000:03:00.0: PME# supported from D3cold
[    0.202463] pci 0000:00:03.0: PCI bridge to [bus 03]
[    0.202470] pci 0000:00:03.0:   bridge window [mem 0xdfc00010-0xdfcfffff]
[    0.202540] pci 0000:04:00.0: [1b4b:9170] type 00 class 0x010601
[    0.202567] pci 0000:04:00.0: reg 0x10: [io  0xc040-0xc047]
[    0.202579] pci 0000:04:00.0: reg 0x14: [io  0xc030-0xc033]
[    0.202589] pci 0000:04:00.0: reg 0x18: [io  0xc020-0xc027]
[    0.202600] pci 0000:04:00.0: reg 0x1c: [io $0xc010-0xc013]
[    0.202611] pci 0000:04:00.0: reg 0x20: [io  0xc000-0xc00f]
[    0.202622] pci 0000:04:00.0: reg 0x24: [mem 0xdfb10000-0xdfb101ff]
[    0.202633] mpci 0000:04:00.0: reg 0x30: [mem 0xdfb00000-0|dfb0ffff pref]
[    0.202670] pci 0000:04:00.0: PME# supported from D3hot
[    0.204466] pci 0000:00:04.0: PCI bridge to [bus 04]
[    0.204471] pci 0000:00:04.0:   bridge window [io  0xc000-0xcfff]
[    0.204476] pci 0000:00:04.0:   bridge window [mem 0xdfb00000-0xdfbfff�f]
[    0.204504] pci_bus 0000:00: on NUMA node 0
[    0.204669] ACPI: PCI Interrupt Link [LNKA] (IRQs 6 7 10 *11 12)
[    0.204776] ACPI: PCI Interrupt Link`[LNKB] (IRQs 6 7 10 11 12) *0, disabled.
[    0.204882] ACPI: PCI Interrupt Link [LNKC] (IRQs 6 7 10 *11 12)
[    0.204985] ACPI: PCI Interrupt link [LNKD] (IRQs 6 *7 10 11 12)
[    0.205089] ACPI: PCI Interrupt Link [LNKE] (IRQs 6 7 *10 11 12)
[    0.205192] ACPI: PCI Interrupt Link [LNKF] (IRQs 6 *7 10 11 12)
[    0.205295] ACPI: PCI Interrupt Link [LNKG] (IRQs 6 7 10 *11 12)
[    0.205399] ACPI: PCI Interrupt Link [LNKH] (IRQs 6 7 *10 11 12)
[    0.205786] ACPI: Enabled 1 GPEs in block 00 to 1F
[    0.205978] SCSI subsystem initialized
[    0.206009] libata version 3.00 loaded.
[    0.206018] ACPI: bus type USB registered
[[32m[    0.206063] usbcore: registered new interface driver usbfs
[    0.206084] usbcore: registered new interface driver hub
[    0.206111] usbcore: registered new device driver usb
[    0.206166] pps_core: LinuxPPS API ver. 1 registered
[    0.206169] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [    0.206178] PTP clock support registered
[    0.206330] Advanced Linux Sound Architecture Driver Initiqlized.
[    0.206352] PCI: Using ACPI for IRQ �outing
[    0.206356] PCI: pci_cache_line_size set to 64 bytes
[    0.206413] e820: reserve RAM buffer [mem 0x0009a400-0x0009ffff]
[    0.206416] �[0me820: reserve RAM buffer [mem 0x7d8fa000-0x7fffffff]
[    0.206418] e820: reserve RAM buffer [mem 0x7e61b000-0x7fffffff]
[    0.206421] e820: reserve RAM buffer [mem 0x7f800000-0x7fffffff]
[    0.206610] Bluetooth: Core ver 2.21
[    0.206625] NET: Registered protocol family 31
[    0.206628] Bluetooth: HCI device and connection manager initialized
[    0.206633] Bluetooth: HCI socket layer initialized
[    0.206636] Bluetooth: L2CAP socket layer initialized
[    0.206644] Bluetooth: SCO socket layer initialized
[    0.206821] clocksource: Switched to clocksource refined-jiffies
[    0.206931] FS-Cache: Loaded
[    0.207005] pnp: PnP ACPI init
[    0.207367] system 00:00: [mem 0xe0000000-0xefffffff] could not be reserved
[    0.207372] system 00:00: [mem 0x7f800000-0x7fffffff] could not be reserved
[    0.207378] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.207483] system 00:01: [io  0x0680-0x069f] has been reserved
[    0.207488] system 00:01: [io  0x0400-0x047f] could not be reserved
[    0.207491] system 00:01: [io  0x0500-0x05fe] has been reserved
[    0.207495] system 00:01: [mem 0xfed00000-0xfedfffff] could not be reserved
[    0.207499] system 00:01: [mem 0x000c0000-0x000dffff] has been reserved
[    0.207503] system 00:01: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.207507] system 00:01: [mem 0xffa00000-0xffffffff] has been reserved
[    0.207510] system 00:01: [mem 0xfee00000-0xfeefffff] has been reserved
[    0.207515] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.207564] pnp 00:02: Plug and Play ACPI device,"IDs PNP0b00 (active)
[    0.207643] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.207715] pnp 00:04: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.208046] system 00:05: [io  0x0a00-0x0a1f] has been reserved
[    0.208050] system 00:05: [io  0x0a20-0x0a2f] has been reserved
[    0.208054] system 00:05: [io  0x0a30-0x0a3f] has been reserved
[    0.208058] system 00:05: [io  0x0a40-0x0a4f] has been reserved
[    0.208061] system 00:05: [io  0x0a50-0x�a5f] has been reserved
[    0.208066] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.208196] pnp: PnP ACPI: found 6 devices
[    8.215669] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.215697] clocksource: Switched to clocksource acpi_pm
[    0.215720] pci 0000:00:01.0: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
[    0.215726] pci 0000:00:01.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[    0.215731] pci 0000:00:01.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[    0.215742] pck 0000:00:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02] add_size 200000 add_align 100000
[    0.215752] pci 0000:00:03.0: bridge window [io  0x1000-0x0ffg] to [bus 03](add_size 1000
[    0.215757] pci 0000:00:03.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03] add_size 200000 add_align 100000
[    0.215767] pci 0000:00:04.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04] add_size 200000 add_align 100000
[    0.215780] pci 0000:00:01.0: res[8]=[mem 0x00100000-0x000fffff] res_vo_dev_res add_size 200000 min_align 100000
[    0.215784] pci 0000:00:01.0: res[8]=[mem 0x00100000-0x002fffff] res_to_dev_res add_size 200000 min_align 100000
[    0.215788] pci 0000:00:01.0: res[9]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.215792] pci 0000:00:01.0: res[9]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.215796] pci 0000:00:02.0: res[9]=[mem 0x00100000-0x000fffff 64bit pref] res_to_devres add_size 200000 min_align 100000
[    0.215800] pci 0000:00:02.0: res[9]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.215804] pci 0000:00:03.0: res[9]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.215808] pci 0000:00:03.0: res[9]=[mem 0x00100000-4x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.215811] pci 0000:00:04.0: res[9]=[mem 0x00100000-0x000fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.215815] pci 0000:00:04.0: res[9]=[mem 0x00100000-0x002fffff 64bit pref] res_to_dev_res add_size 200000 min_align 100000
[    0.215819] pci 0000:00:01.0: res[7]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.215823] pci 0000:00:01.0: res[7]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.215826] pci 0000:00:03.0: res[7]=[io  0x1000-0x0fff] res_to_dev_res add_size 1000 min_align 1000
[    0.215830] pci 0000:00:03.0: res[7]=[io  0x1000-0x1fff] res_to_dev_res add_size 1000 min_align 1000
[    0.215838]0pci 0000:00:01.0: BAR 8: assigned [mem 0x80000000-0x801fffff]
[    0.215844] pci 0000:00:01.0: BAR 9: assigned [mem 0x180000000-0x1801fffff 64bit pref]
[ 0  0.215850] pci 0000:00:02.0: BAR 9: assigned [mem 0x180200000-0x1803fffff 64bit pref]
[    0.215856] pci 0000:00:03.0: BAR 9: assigned [mem 0x180400000-0x1805fffff 64bit pref]
[    p.215862] pci 0000:00:04.0: BAR 9: assigned [mem 0x180600000-0x1807fffff 64bit pref]
[    0.215867] pci 0000:00:01.0: BAR 7: assigned [io  0x1000-0x1fff]
[    0.215872] pci 0000:00:03.0: BAR 7: assigned [io  0x2000-0x2fff]
[    0.215877] pci 0000:00:01.0: PCI bridge to [bus 01]
[    0.215881] pci 0000:00:01.0:   bridge window [io  0x1000-0x1fff]
[    0.215888] pci 0000:00:01.0:   bridge window _mem 0x80000000-0x801fffff]
[    0.215894] pci 0000:00:01.0:   bridge window [mem 0x180000000-0x1801fffff 64bit pref]
[    0.215903] pci 0000:00:02.0: PCI bridge to [bus 02]
[    0.215907] pci 0000:00:02.0:   bridge window [io  0xd000-0xdfff]
[    0.215913] pci 0000:00:02.0:   bridge window [mgm 0xdfd00000-0xdfdfffff]
[    0.215919] pci 0000:00:02.0:   bridge window [mem 0x180200000-0x1803fffff 64bit pref]
[    0.215927] pci 0000:00:03.0: PCI bridge to [bus 03]
[    0.215931] pci 0000:00:03.0:   bridge window [io  0x2000-0x2fff]
[    0.215937] pci 0000:00:03.0:   bridge window [mem 0xdfc00000-0xdfcfffff]
[    0.215943] pci 0000:00:03.0:   bridge window [mem 0x180400000-0x1805fffff 64bit pref]
[    0.215952] pci 0000:00:04.0: PCI bridge to [bus 04]
[    0.215955] pci 0000:00:04.0:   bridge window [io  0xc000-0xcfff]
[    0.215961] pci 0000:00:04.0:   bridge window [mem 0xdfb00000-0xdfbfffff]
[    0.215967] pci 0000:00:04.0:   bridge window [mem 0x180600000-0x1807fffff 64bit pref]
[    0.215978] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.215981] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.215985] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.215988] pci_bus 0000:00: resource 7 [mem 0x80000000-0xdfffffff window]
[    0.215991] pci_bus 0000:00: resource 8 [mem 0x180000000-0xfffffffgf window]
[    0.215995] pci_bus 0000:01: resource 0 [io  0x1000-0x1fff]
[    0.215998] pci_bus 0000:01: resource 1 [mem 0x80000000-0x801fffff]
[    0.216001] pci_bus 0000:01: resource 2 [mem 0x180000000-0x1801fffff 64bit pref]
[    0.216004] pci_bus 0000:02: resource 0 [io  0xd000-0xdfff]
[    0.216008] pci_bus 0000:02: resource 1 [mem 0xdfd00000-0xdfdfffff]
[   !0.216011] pci_bus 0000:02: resource 2 [mem 0x180200000-0x1803fffff 64bit pref]
[    0.216014] pci_bus 0000:03: resource 0 [io  0x2000-0x2fff]
[    0.216017] pci_bus"0000:03: resource 1 [mem 0xdfc00000-0xdfcfffff]
[    0.216021] pci_bus 0000:03: resource 2 [mem 0x180400000-0x1805fffff 64bit pref]
[    0.216024] pci_bus 00p0:04: resource 0 [io  0xc000-0xcfff]
[    0.216027] pci_bus 0000:04: resource 1 [mem 0xdfb00000-0xdfbfffff]
[    0.216031] pci_bus 0000:04: resource 2 [mem 0x180�00000-0x1807fffff 64bit pref]
[    0.216072]�NET: Registered protocol family 2
[    0.216278] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.216360] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.216532] TCP: Hash tables configured (established 32768 bind 32768)
[    0.216601] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.216629] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.216754] NET: Registered protocol family 1
[    0.216892] RPC: Registered named UNIX socket transport module.
[$   0.216895] RPC: Registered udp transport module.
[    0.216897] RPC[    0.216898] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.228011] PCI: CLS 64 bytes, default 64
[    0.228103] Unpacking initramfs...
[    1.098594] Freeing initrd memory: 4212K
[    1.098610] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    1.098614] software IO TLB [mem 0x794dd000-0x7d4dd000] (64MB) mapped at [ffff8800794dd000-ffff88007d4dcfff]
[    1.106023] VFS: Disk quotas dquot_6.6.0
[    1.106100] VFS: Dquot-cache hash table entries: 512 (order 0, 4496 bytes)
[    1.114088] NFS: Registering the id_resolver key type
[    1.114109] Key type id_resolver registered
[    q.114112] Key type id_legacy registered
[    1.114119] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.136105] Key type cifs.spnego registered
[    1.136118] Key type cifs.idmap registered
[    1.136212] fuse init (API version 7.23)
[    1.141029] NET: Registered protocol family 38
[    1.141042] async_tx: api initialized (async)
[    1.141141] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    1.141221] io scheduler noop registered
[    1.141226] io scheduler deadline registered
[    1.141284] io scheduler cfq registered (default)
[    1.141384] io scheduler bfq registered
[    1.141387] BFQ I/O-scheduler: v7r11
[    1.141942] gpio_it87: Found Chip IT8732 rev �. 64 GPIO lines starting at 0a10h
[    1.142603] pcieport 0000:00:04.0: can't derive routing for PCI INT A
[  " 1.142607] pcieport 0000:00:04.0: PCI INT A: no GSI
[    1.142727] intel_idle: MWAIT substates: 0x3000020
[    1.142731] intel_idle: v0.4.1 model 0x4D
[    1.142733] intel_idle: lapic_timer_reliable_states 0xffffffff
[    1.142966] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[    1.142972] ACPI: Power Button [PWRF]
[    1.146486] ioatdma: Intel(R) QuickData Technology Driver 4.00
[    1.146728] Serial: 8250/16550 driver, 4 ports, IRQ sharing eoabled
[    1.167110] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    1.187526] 00:04: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 16550A
[    1.188014] Linux agpgart interface v0.103
[    1.188072] [drm] Initialized drm 1.1.0 20060810
[    1.190511] loop: module loaded
[    1.190920] gpio_ich: GPIO from 388 to 447 on gpio_ich
[    1.191073] mpt3sas version 12.100.00.00 loaded
[    1.206988] ahci 0000:00:17.0: version 3.0
[    1.217783] ahci 0000:00:17.0: AHCI 0001.0300 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[    1.217790] ahci 0000:00:17.0: flags: 64bit ncq led clo pio deso sadm sds apst [    1.217837]`do_marvell_9170_recover: ignoring PCI device (8086:1f22) at PCI#0
[    1.217875] do_marvell_9170_recover: ignoring PCI device (8086:1f22) at PCI#0
[    1.217910] do_marvell_9170_recover: ignoring PCI device (8086:1f22) at PCI#0
[    1.217945] do_marvell_9170_recover: ignoring PCI device (8086:1f22) at PCI#0
[    1.219576] scsi�host0: ahci
[    1.222755] scsi host1: ahci
[    1.222973] scsi host2: ahci
[    1.223158] scsi host3: ahci
[    1.223234] ata1: SATA max UDMA/133 abar m2048@0xdff36000 port 0xdff36100 irq 88
[    1.223238] ata2: SATA max UDMA/133 abar m2048@0xdff36000 port 0xdff36180 irq 88
[    1.223241] ata3: S�TA max UDMA/133 abar m2048@0xdff36000 port 0xdff36200 irq 88
[    1.223244] ata4: SATA max UDMA/133 abar m2048@0xdff36000 port 0xdff36280 irq 88
[    1.233754] ahci 0000:00:18.0: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    1.233761] ahci 0000:00:18.0: flags: 64bit ncq led clo pio deso sadm sds apst [    1.233805] do_marvell_9170_recover: ignoring PCI device (8086:1f32) at PCI#0
[    1.233837] do_marvell_9170_recover: ignoring PCI device (8086:1f32) at PCI#0
[    1.234207] scsi host4: ahci
[    1.234362] scsi host5: ahci
[    1.234439] ata5: SATA max UDMA/133 abar m2048@0xdff35000 port 0xdff35100 irq 89
[    1.234443] ata6: SATQ max UDMA/133 abar m2048@0xdff35000 port 0xdff35180 irq 89
[    1.234656] ahci 0000:02:00.0: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    1.234662] ahci 0000:02:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs [    1.234718] ReadyNAS model: ReadyNAS 3138
[    1.234722] do_marvell_9170_recover: start_engine() called for PCI#2 port 0
[    1.234724] do_marvell_9170_recover: saving PCI#2 and �EV
[    1.234728] marvell_9170_save_pci_dev: pci[4]=100407
[    1.234731] marvell_9170_save_pci_dev: pci[c]=10
[    1.234734] marvell_9170_save_pci_dev: pci[10]=d041
[    1.234737] marvell_9170_save_pci_dev: pci[14]=d031
[    1.234740] marvell_9170_save_pci_dev: pci[18]=d021
[    1.234744] marvell_9170_save_pci_dev: pci[1c]=d011
[    1.234747] marvell_9170_save_pci_dev[[0m� pci[20]=d001
[    1.234750] marvell_9170_save_pci_dev: pci[24]=dfd10000
[    1.234753] marvell_9170_save_pci_dev: pci[30]=dfd00000
[    1.234756] marvell_9170_save_pci_dev: pci[3c]=10b
[    1.234759] marvell_9170_save_pci_dev: pci[44]=0
[    1.234762] marvell_9170_save_pci_dev: pci[50]=17005
[    q.234765] marvell_9170_save_pci_dev: pci[54]=fee0f00c
[    1.234768] marvell_9170_save_pci_dev: pci[58]=41c1
[    1.234771] marvell_9170_save_pci_dev: pci[78]=92027
[    1.234774] marvell_9170_save_pci_dev: pci[80]=10120040
[    1.234777] marvell_9170_save_pci_dev: pci[a0]=2
[    1.234779] marvell_9170_save_pci_dev: dev[4]=80000002
[    1.234782] marvell_9170_save_pci_dev: dev[100]=7a840000
[    1.234785] marvell_9170_save_pci_dev: dev[104]=1
[    1.234787] marvell_9170_save_pci_dev: dev[108]=7a840400
[    1.234790] marvell_9170_save_pci_dev: dev[10c]=1
[    1.234792] marvell_9170_save_pci_dev: dev[110]=ffffffff
[    1.234794] marvell_9170_save_pci_dev: dev[114]=7840007f
[    1.234796] marvell_9170_save_pci_dev: dev[118]=710011
[    1.234799] marvell_9170_save_pci_dev: dev[180]=98500
[    1.234801] marvell_9170_save_pci_dev: dev[184]=0
[    1.234804] marvell_9170_save_pci_dev: dev[188]=98540
[    1.234807] marvell_9170_save_pci_dev: dev[18c]=0
[    1.234809] marvell_9170_save_pci_dev: dev[190]=ffffffff
[    1.234811] marvell_9170_save_pci_dev: dev[194]=7840007f
[    1.234813] marvell_9170_save_pci_dev: dev[198]=710011
[    1.234855] do_marvell_9170_recover: start_engine() called for PCI#2 port 1
[    1.234857] do_marvell_9170_recover: saving PCI#2 and DEV
[    1.234860] marvell_9170_save_pci_dev: pci[4]=100407
[    1.234863] marvell_917�_save_pci_dev: pci[c]=10
[    1.234866] marvell_9170_save_pci_dev: pci[10]=d041
[    1.234869] marvell_9170_save_pci_dev: pci[14]=d031
[    1.234872] marvell_9170_save_pci_dev: pci[18]=d021
[    1.2�4875] marvell_9170_save_pci_dev: pci[1c]=d011
[    1.234878] marvell_9170_save_pci_dev: pci[20]=d001
[    1.234881] marvell_9170_save_pci_dev: pci[24]=dfd10000
[    1.234884] marvell_9170_save_pci_dev
