If you want to know more about TDA7377, you can read its datasheet.If you want to know more about TDA7377, you can read its datasheet.
The 1N5711 is a very high speed small-signal Schottky diode which is well suited for high level detecting, mixing, switching, gating, log or A-D converting, video detecting, frequency discriminating, sampling, and wave shaping.
This blog will introduce 1N5711 systematically from its features, dimensions to its specifications, applications, also including 1N5711 datasheet and so much more.
1N5711 Features
- Guardring for over-voltage protection and high reliability
- Picosecond switching speed
- Very low turn-on voltage
- High breakdown voltage up to 70V
- Matched characteristics on request
- UHF/VHF detection
- Pulse applications with broad dynamic range
- Protection of MOS devices
- Steering, biasing and coupling in fast switching and low logic level
1N5711 Applications
- UHF/VHF detection
1N5711 Dimensions
The following figure is the diagram of 1N5711 dimensions.
Dimensions In Millimeters And (inches)
If you want to know more about 1N5711, you can read its datasheet.
