Product Overview
2N2222A is a NPN transistor hence the collector and emitter will be left open (Reverse biased) when the base pin is held at ground and will be closed (Forward biased) when a signal is provided to base pin. 2N2222A has a gain value of 110 to 800, this value determines the amplification capacity of the transistor. The maximum amount of current that could flow through the Collector pin is 800mA, hence we cannot connect loads that consume more than 800mA using this transistor. To bias a transistor we have to supply current to base pin, this current (IB) should be limited to 5mA.
This blog will introduce 2N2222A systematically from its features, pinout to its specifications, applications, also including 2N2222A datasheet and so much more.
2N2222A Features
- Bi-Polar high current NPN Transistor
- DC Current Gain (hFE) is 100
- Continuous Collector current (IC) is 800mA
- Emitter Base Voltage (VBE) is 6V
- Collector Emitter Voltage (VCE) is 30V
- Base Current(IB) is 5mA maximum
- Available in To-92 Package
2N2222A Pinout
The pin configuration of the 2N2222A transistor is shown below. This transistor includes three pins & its each pin functionality is discussed below.
2N2222A Advantages
The main advantages of using the 2N2222 transistor include the following.
- This is the most commonly used type of transistor
- In electronic circuits, most of the switching applications can be done by using this transistor
- It is capable of handling fairly high magnitude currents as compared to other similar transistors.
- This transistor switches the load current with 800 mA through it, which is high as compared to others.
- So this capability will make the device ideal in the applications of linear amplifiers.
- Small size
- Less weight
- Voltage gain is high
- Low source voltage
- Low cost
- Longer life
If you want to know more about 2N2222A, you can read its datasheet.
