So just a short one today to describe briefly how to change option bytes. The documentation does not seem to have examples, but I was finally able to stumble my way into getting it working by looking at the methods and steps of a few different articles about changing option bytes for other stm32 chips.
With the stm32g031, you must use the stm32l4x flash driver. This may vary for your chip, so research that. Since I found that out the long way round, I hope it saves you time. Using my new friend openocd, I wanted to enable the BOR enable bit in the option bytes (change from 0xfffffeaa to 0xffffffaa). It's a one bit change, how hard could it be?
Earlier I showed how you can read option bytes. You can verify they are set at the default. This command:
openocd -d0 -f read-opt-bytes-1 -c "stm32l4x option_read 0 0x20" -c "exit"
gives this result:
Option Register: <0x40022020> = 0xfffffeaa
And this matches the datasheet RM0444 p. 81. Hooray!
I've tried every combination of option_write and option_load I can think of based on what others had got to work for them, and I was finally able to toggle one single bit in the option bytes. I had to use these two commands in order:
openocd -f read-opt-bytes-1 -c "stm32l4x option_write 0 0x20 0xffffffaa 0xffffffaa" -c "reset" -c "exit"
openocd -f read-opt-bytes-1 -c "stm32l4x option_load 0 0x20" -c "reset" -c "exit"
Then we have the new values: Option Register: <0x40022020> = 0xffffffaa
Recall from earlier, that I had made my own read-opt-bytes-1 config file for openocd. It basically just sets some defaults, but more importantly, let's me specify exactly which st-linkv2 interface I want to use when there are more than one plugged in at one time. This is done with the hla_serial line in the config file...
hla_serial "\x55\x3f\x66\x06\x48\x3f\x57\x54\x12\x27\x07\x3f"
It would be nice if openocd could read this style ID instead: 55FF66064887575412270787, but I'll take what I can get.
Cheers!
... also, *changing* the BOR bits from default settings (BOR turned off) did help with power ups when the supply voltage ramps up slowly. If you have something like that, be sure to turn on the BOR EN bit. :-)
*update* Thanks to Paul F. on the openocd chat for catching the error in my build environment. We're now running openocd 0.11 (the latest release). And also thank you for the config tips! You do not need the full path in the config files to get to interface and target directories, and the creation of the dap is automatic. Now, the new shorter format of my config files are something like this:
source [find interface/stlink.cfg] source [find target/stm32g0x.cfg] gdb_memory_map enable gdb_flash_program enable adapter serial "\x55\x3f\x66\x06\x48\x3f\x57\x54\x12\x27\x07\x3f" gdb_port disabled tcl_port disabled telnet_port disabled init
Cleaner. Smaller. Learn something every day!
