TIP102 Transistor Datasheet
daenorthughdaenorthugh wrote 12/04/2021 at 02:59 • 2 min read • Like
Product Overview
The TIP102 is a silicon Epitaxial-Base NPN power transistor in monolithic Darlington configuration mounted in TO-220 plastic package. It is intented for use in power linear and switching applications.
TIP102 3D Model
TIP102 Features
TIP102 Pinout
The following figure is the diagram of TIP102 pinout.
TIP102 Pinout
TIP102 Applications
■ linear and switching industrial equipment
■ audio power amplifier
■ general power switching
■ DC-AC converter
■ easy driver for low voltage DC motor
If you want to know more about TIP102, you can read its datasheet.
Like
