What a pain
jlbrian7jlbrian7 wrote 01/07/2022 at 14:41 • 3 min read • Like
VBA Excel Script
Private Sub CommandButton1_Click()
    Module1.createLetters
End Sub
# Module1 ###############################################################
Dim LColumns(16383) As String
Sub createLetters()
        Module1.setColumns
        Sheets.Add.Name = "Letters"
        For x = 0 To 16383
            Sheets("Letters").Cells(1, x + 1).Value = LColumns(x)
            Sheets("Letters").Cells(2, x + 1).Value = x
        Next x
        ActiveWorkbook.Save
End Sub
Sub setColumns()
    Dim col_count As Integer
    Dim letters As Variant
    Dim ColumnL As String
    letters = Array("A", "B", "C", "D", "E", "F", "G", "H", "I", "J", "K", "L", "M", "N", "O", "P", "Q", "R", "S", "T", "U", "V", "W", "X", "Y", "Z")
    col_count = 0
    While col_count < 16384
        If col_count < 26 Then
            ColumnL = letters(col_count Mod 26)
        ElseIf (col_count >= 26) And (col_count < ((26 * 26) + 26)) Then
            ColumnL = letters(Int((col_count / 26) - 1) Mod 26) & letters(col_count Mod 26)
        Else
            If Int((col_count / 26) - 1) Mod 26 < 25 Then
                ColumnL = letters(Int((col_count / 26 / 26) - 1)) & letters(Int((col_count / 26) - 1) Mod 26) & letters(col_count Mod 26)
            Else
                ColumnL = letters(Int((col_count / 26 / 26) - 2)) & letters(Int((col_count / 26) - 1) Mod 26) & letters(col_count Mod 26)
            End If
        End If
        LColumns(col_count) = ColumnL
        col_count = col_count + 1
    Wend
End Sub
Python
letters = ['A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z']
col_count = 0
columns = []
while col_count < 16384:
    if col_count < 26:
        column = letters[col_count%26]
    elif col_count >= 26 and col_count < (26*26) + 26:
        column = letters[(int(col_count/26)-1)%26] + letters[col_count%26]
    else:
        if int(col_count/26)-1)%26 < 25:
            column = letters[(int(col_count/26/26)-1)%26] +  letters[(int(col_count/26)-1)%26] + letters[col_count%26]
        else:
             column = letters[(int(col_count/26/26)-2)%26] +  letters[(int(col_count/26)-1)%26] + letters[col_count%26]
    col_count += 1
    columns.append(column)
Like
Rich text editor
