Time for another Electronics Goldmine analysis!
2x Box of ICs (>50)
19135; $10.00 ($2.99 when I bought them.)
- 2x CD4002CN - Dual 4-input NOR Gate
- 1x CD4020BCN - 14 bit up counter/divider
- 1x CD4034BE - 8 bit ser/par to ser/par shift register
- 2x CD4040BF - 12 bit up counter/divider
- 1x CD4049UBD - 6-Channel inverting buffer
- 2x CD4071BE - Quad 2-input OR Gate
- 2x 4081BDC - Quad 2-input AND Gate
- 1x CD4093BE - Quad 2-input NAND Gate
- 1x HEF4520BP - Dual 4 bit up counter
- 2x TC4528BP - Dual monostable multivibrator
- 1x CD40103BE - 8 bit down counter
- 2x HCF40106BE - Hex Schmitt-Trigger Inverter
- 3x CD40192BE - 4 bit up/down decade counter
- 1x 74F04DC - Hex inverter
- 1x SN74LS04N ``
- 1x SN74LS08N - Quad 2-input AND Gate
- 1x N74H08 ``
- 1x SN74F08N ``
- 1x MM74C14N - Hex Schmitt-Trigger Inverter
- 1x 74LS14N ``
- 1x SNJ54S32J - Quad 2-input OR gate
- 3x 74ACTQ32PC ``
- 4x SN7433N - Quad 2-input NOR buffer — open collectors
- 1x SN74ALS00AN - Quad 2-input NAND gate
- 1x 74H106PC - Dual negative-edge-triggered flip-flop
- 3x SN74S139N - 2 to 4 line demultiplexer/decoder
- 1x CD74HC139E ``
- 2x SN74LS147N - 10 to 4 bit priority encoder
- 1x MC74HC154N - 4 to 16 line demultiplexer/decoder
- 2x SN74HC154NT ``
- 1x SN74154N ``
- 2x CD74HCT165E - 8 bit ser/par to ser shift register (complem. outputs)
- 1x 74F166N - 16 bit ser/par in, ser out shift register
- 2x 74F169N - 4 bit up/down counter
- 1x SN74196N - Up decade counter
- 3x P74PCT240PC - Octal inverted buffer, tri-state
- 1x MC74HC245 - 8 bit bus transceiver
- 1x 74AC245PC ``
- 2x 74F259N - 8 bit latch
- 2x 74283-PC - 4 bit binary adder
- 1x SN74LS353N - Dual 4 to 1 line inverting data selector, tri-state
- 1x 74HCT365N - Hex non-inverting buffer; tri-state
- 5x 74ABT374N - Octal D-type flip flop
- 1x 74S374N ``
- 1x 74F524PC - 8 bit registered comparator
- 4x SN74ALS540N - 8 channel inverting buffer, ti-state
- 1x 74F544N - 8 bit bus transceiver
- 1x 74F573N - D-type octal latch
- 2x 74F676PC - 16 bit ser/par in, ser out shift register
- 2x MM74HC4053N - Triple 2-channel analog multiplexer/demultiplexer
- 1x MC54HC7266J - Quad 2-input XNOR gate
- 1x MC146805E2P - 8 bit microcontroller! (datasheet)
- 3x SN75C188N - Quad line driver/transmitter?
- 1x 1488P - Quad line driver?
- 2x MC14490P - Hex debouncer
- 2x MC14519B - 4 bit AND/OR sel. / Quad 2-Channel data sel. / Quad 2-input XNOR Gate (datasheet)
- 3x MC14522B - Down decade counter
- 1x MC1496L - RF Modulator/Demodulator
- 1x MC14174B - Hex D-type flip flop
- 2x MC145145P2 - 4 bit data bus frequency synthesizer?
- 2x HD14020BP - Triple 3-input NAND Gate
- 1x MC14023BCP ``
- 1x MC14519 - PLL frequency synthesizer
- 1x SN75155P - RS-232 Transceiver
- 1x SN75176AP - Differential Bus Transceiver
Now that's a long list!
104 ICs—that's 52 per box.
8/10: This one was definitely worth it. Although there were fewer ICs in the boxes this time, there was a better variety, and another reason for this was probably the larger chips—less DIP-8s and more of those super-wide, crazy ones.
2x Super Electronic Surprise Box
9321; $7.95 each
SO.
MANY.
CAPACITORS.
If a component isn’t listed here, it’s probably a capacitor.
Also:
- masses of resistors
- those small, dark blue ones that there’s a ton of on the first picture have values 1071Ω and 7321Ω
- the big, light blue ones are all pre-bent and 100Ω
- two sandstone resistors
- some random resistors
- crazy amounts of diodes
- some weird-looking ferrites?
- a lamp base with wires—I’m sure some cool mesh-networking thing could be made with these :D
- a speaker!
- two stereo RCA connectors
- two rectifiers
- some switches
- those black switches (DPST) have a nice insulation between the two sides
- springs!
- springy!
- LEDs!
- glowy!
- A hex nut
- A potentiometer
- A speaker with some weird connector
- Some SMD inductors
Box 2!
Again, many capacitors.
Also:
- A zip-tie—A true marvel of modern electronics.
- lots more of those weird ferries
- some more of those weird-valued resistors
- a few more of those 100Ω resistors
- some more random resistors
- SMD sockets
- 3 more RCA jacks (these are a different type)
- some more SMD inductors
- 2 more potentiometers
- more springs!
- even springier!
- more LEDs!
- even glowier!
- crazy amounts of those black DPST switches
- some form of wire connector
- You can remove the orange part, insert wires, push it back in and the two wires are connected. Not sure how else to describe these.
- some kind of electromechanical valve
- some plastic mounting parts?
- That static-resistant bag.
- This thing is amazing. There’s 500pcs of HLMP-6400 (small, yellow through-hole LEDs with pre-bent leads) inside.
- I’ll have to make something cool with these. Suggestions are welcome!
8/10: Both these boxes were great.
However, there's an important piece of advice I need to give you:
Don't order these by themselves, and don't order more than one.
It's obvious that the contents of these change from week to week, so it's not worth buying too many at once—consider them an add-on to whatever you're buying (albeit one that is quite heavy and drives up the shipping cost by a few dollars)
Thanks for reading!
If you liked this, please consider following me.
alpha_ninja
alpha_ninja
