The Distributed Resource Scheduler (DRS) is a helpful feature that you can enable in VMware cluster configuration. The DRS is used for load balancing in vSphere clusters to ensure that VMs have enough resources to run with enough performance. Read how to configure DRS in VMware vSphere to learn which VMware DRS settings can be useful in your vSphere environment.
![](https://cdn.hackaday.io/images/4290641662726608929.png)
