I'm going to start putting my silly/just-for-fun/rainy-day projects up in little logs like this. If I actually take one on, I'll put up an actual project page for it.
To start off, here's one that came from having something "too good to toss, but not worth enough to sell" that I think I could improve. In this case, it's an IBM 8503 greyscale VGA monitor. While it is only greyscale, this is not the main issue. In fact, it might be fun to add an amber or green gel across the front and get an even better old-school vibe. The problem is that a bean-counter at Big Blue decided to save a 15th of a penny per unit by not including red or blue signal wires. Thus hobbled, it doesn't even actually produce a greyscale image! It only displays the green channel of the source material, which is very disappointing.
At first, I was planning to transplant a new cable and install a resistor mixer to get true greyscale, but then I had an epiphany about possibly adding full color to this beast! The plan centers around a cheap color filter wheel from a DLP projector. Build a synchronized pair into some goggles, and you can make any switchable white light source into any color you want, given the proper timing.
In the case of the monitor, if you could ensure that only the red, green, or blue image was displayed while the respective color wheel sector was being peered through, the image would be in color. The first plan was a frame-sequential concept, but that would reduce the frame-rate to a nominal 20Hz, and I'm already sensitive to slow frame-rates (I can see the flicker in older LED brake lights, for example). It would also require a lot of very fast electronics to get everything synched up. That's when another epiphany hit me: why does it need to be synchronized at all? I have access to all three color signals at all times. If the wheel spins fast enough, and switching between the three video signals is fast enough, it could run at any arbitrary speed.
While searching for video switchers, I learned about chips like the MAX454. It's a high-speed, analog, 4-channel multiplexer with a unity-gain video amplifier stage. The datasheet says it has a 50MHz bandwidth, so I figure it can switch in 20-50ns, which is hundreds of times faster than the line rate of a 640x480 VGA display. I'm beginning to think this might work!
The color wheel goggles are probably the limiting factor, but they can be run open-loop at whatever speed I want, as long as no rapid, unplanned disassembly occurs. Two wheels will require the two wheels to stay synchronized, but perhaps there is some optical trickery that can allow the use of a single wheel for both eyes. I might just make a monocular to test the concept.
So, here's the plan:
1. Break out all the VGA signals to some perfboard.
2. Mount the '454 and connect each color channel to it.
3. Run the '454's output to the gray” (green) input on the monitor (and pass all other signals through unchanged).
4. Build the goggles, with a way to extract a 2-bit address from the current sector of the wheel.
5. Connect the address to the '454.
6. Try it out with something colorful!
Stretch Goals
I found an eBay listing for four MAX454s for cheap, so I grabbed them. Since they each have four channels, I could, in theory, use the fourth input to switch in the aforementioned greyscale mixer, and have a standard greyscale image, when I don't want to bother with the head-gear.
Speaking of head-gear, I've always wanted a shutter-glasses-based, stereoscopic display system. I even have pairs of both wired and wireless glasses. If I set up a system with two VGA outputs, I could use the other three chips to make a similar, asynchronous (open-loop) 3-D display on one of my color CRTs.
RunnerPack
Sounds like a good plan for trying something few people would imagine. Hint: why not go for a two color setup with the 3rd mixed in? The first color movies used alternating red and green filters. I would try using active 3D glasses (should be cheap since no one uses them). Synchronization here doesn't require a lot of bandwidth. A CD4051 should be sufficient.
https://en.wikipedia.org/wiki/Kinemacolor
Thomas,
Thanks for the comment and link! That has a rather interesting aesthetic. I've seen films/clips like that before, but I always assumed they were just poorly colorized b&w footage 🤷🏻♂️
I'm not entirely sure how I would go about that in my project, though. I already have the DLP wheels and the mux chips, so I'll likely just proceed with RGB, but more experimentation is definitely called for.
It's funny that you mention shutter glasses, though, as I own both wired and wireless ones made for VGA.
Good to see that you're still toying with the idea!
Thinking of VGA color and your specific IBM monitor: manipulating the good old VGA LUT is also a solution for experimenting with Color->BW transformation without any soldering. Properly done that can replace tinkering with MUXes and resistor.
