Public lab spectrometer v2.5 (mod 3.0.1)
david-h-haffner-srDavid H Haffner Sr wrote 04/24/2016 at 09:17 • 3 min read • Like
New DVD grating upgrade
Old DVD grating set up
http://publiclab.org/profile/dhaffnersrThis is a spectrometer kit I bought from Plab about 4 months ago, I have made several modifications since then, here are some specs on how it stands now:
1) Spectrometer bandwidth = 5
2) Slit width = 0.09
3) Slit length = 19mm
4) Distance of slit to camera = 48mm
5) Cuvette distance to slit = 29mm
6) Cuvette distance to camera = 78.13mm
7) Width of DVD grating = 17.90mm
8) DVD piece used is 8.5gb - ruling density = 2770 lines/mm = 0.36mm groove spacing = 360nm
JDEPC-ov04 camera
Specs:
Sensor Type
OV2643
Active pixel array area
3590um * 2270um
Power Supply
Core
1.5 VDC ± 5%
Analog
2.6 to 3.0 Vdc
I/O
1.70V ~3.0Vdc
Temperature Range
Operation
-20°C ~ 70°C
Stable Image
0°C ~ 50°C
Output formats
YUV / Ycb Cr 4:2:2 ; RGB 5:6:5 / 5:5:5 ;GBR 4:4:4 ; 8/10BIT RAW RGB Data
Optical Format
1/4 inch
Frame rate
15 fps for UXGA,30fps for SVGA, 30fps for 720P,60 fps for QVGA and any lower resolution
Scan mode
Progressive
Maximum Exposure Interval
1227Xtrow
Gamma Correction
Programmable
Pixel Size
2.2 um x 2.2um
Full resolution
1600x 1200 pixels (UXGA)
Sensor Package Dimension
5035um x 4635um
Like
Rich text editor
