Also, have you noticed how cheap these are: https://datasheet.lcsc.com/lcsc/1809010913_Hangzhou-Ruimeng-Tech-MS90C386B_C231931.pdf
The number of GPIO pins on RP2040 perfectly matches the number of TTL outputs and 2 clock inputs, meaning you can get yourself a nice 1.225 GHz 4-channel differential logic analyzer if you design the board yourself. ;-)
Nice Rust demo! I might use it one day.
