< TO "TYPE 2" | <HOME> | TO "TYPE 4">
"TYPE 3" is used in Renault Laguna 1 (x56) / 1994-2001
- It is a Sample based system
- The speech synthesizer hardware is integrated into the cluster. (Cluster must have green connector [HIGH version])
- Languages: French, English, German, italian, Spanish, Dutch
PHASE 1:
Phase 1 parts have a seperate distance counter display in the center of the cluster. Phase 1 uses a red, a blue and a green connector.
PHASE 2:
Phase 2 parts show the distance counter in the upper borardcomputer display. Phase 2 has a red, a grey and a green connector. Phase 2 uses different connectors.
Phase 2 speech synthesizer hardware:
ROM : 44PIN OKI M531602C (DATASHEET) (2MB)
FPGA : PIOLOGO3 (Toshiba) TC110G08AF* (DATASHEET)
MICROCONTROLLER : Texas Instruments TMS370C056 (DATASHEET) and D36011FNA (UNKNOWN)
* I´m not sure if "PIOLOGO3" is the speech synthesizer... At least it has direct connections to the voice ROM... Maybe it is a FPGA or something like that. If you search for the number below PIOLOGO3 (TC110G08AF) you will find some old Harddisks with this chip... I am pretty sure a Harddisk does not have a speech synthesizer...
EDIT: I was right... it is a gate array. TC... sounded a lot like a partnumber from Toshiba. some searches later i found the Toshiba TC110G gate array in the version 08 (TC110G08) with around 3200 usable gates. >DATASHEET<... I have to make some measurements to see wich of the IC´s generates the Voice output that is fed into the amp...
I finally found a ROM Chip that looks exactly like our MASKROM ... I think its time to order a adapter so that i can try to dump it... M27C160 (DATASHEET) seems to be the regular version of the MSM531602E
Videos:
Changing language with tester on PHASE 2:
Voice example Phase 1 english:
BaumInventions
