Decoding the 47k Ohm Resistor Color Code
lorryluolorryluo wrote 12/26/2023 at 06:54 • 2 min read • Like
Resistors play a crucial role in electronic circuits, and their values are often represented by a color code system. Let's decode the color bands of a 47k ohm resistor to understand how this coding works and determine the resistor's value.
Overview of a 47k Ohm Resistor:
A 47k ohm resistor has a resistance value of 47,000 ohms, and the "k" indicates that the resistance is in thousands.
Color Bands on a 47k Resistor:
A 47k ohm resistor typically has four color bands. Let's interpret each band:
Color Bands:
  1. First Band (Digit 1): Yellow (4)
  2. Second Band (Digit 2): Violet (7)
  3. Third Band (Multiplier): Orange (10^3)
  4. Fourth Band (Tolerance): No Color (20%)
Decoding the Value:
Color Interpretation:
Calculating the Resistance:
Tolerance:
Representation in Ohms:
Color Code Summary:
Conclusion: Understanding the Color Code:
Decoding the color bands of a 47k ohm resistor involves associating each color with a numerical value and multiplier. In this case, Yellow represents 4, Violet represents 7, Orange represents a multiplier of 10^3, and the absence of color in the fourth band defaults to a tolerance of ±20%. By combining these elements, we arrive at the resistor's value of 47,000 ohms or 47k ohms. Understanding the color code system empowers engineers and hobbyists to quickly identify resistor values for effective circuit design.
Like
