// Videx Videoterm Card Emulator
// by Augusto Baffa feb 2024
// Based on Apple II Simulator
// by Peter Koch, May 6, 1993
int videx_slot = 3;
bool card_videx = true;
bool card_videx_mem_on = false;
bool card_videx_80col = false;
class VidexCard {
//notes:
// To turn on/off 80 columns mode:
// Write at 0xC058 or 0xC059
// card_videx_80col = (addr == 0xc059);
// To Control the card:
// IOSEL (0xC300-C3FFF - slot 3)
// Read
// r = videxcard.getRomIoSel(addr & 0x1FF);
// card_videx_mem_on = true;
// Write
// DEVSEL (0xC0B0-C0BF - slot 3)
// Read
// r = videxcard.getC0SLOTX(addr);
// Write
// videxcard.putC0SLOTX(addr, val);
// IOSTB (0xC800-CFFF)
// Read
// if (((addr >> 9) & 0b11) == 0b11) card_videx_mem_on = false;
// if (card_videx_mem_on && addr >= 0xC800 && addr <= 0xCDFF)
// r = videxcard.getSLOTC8XX(addr & 0x7ff);
// Write
// videxcard.putSLOTC8XX(addr - 0xC800, val);
// To Render:
//for (int y = 0; y < 25; y++) {
// for (int x = 0; x < 80; x++) {
// int vkeycode = videxcard.getCSLOTXX(x, y); // get ascii code from memory
// bool vinverse = videxcard.isCursorPosition(x, y); // check cursor position to inverse
// for (int i = 0; i < 9; i++) {
// int video_bits = videxcard.getVideoBits(vkeycode, i); // get bits for the current char/scanline
// if (vinverse)
// display_bit_80col(renderer, x, y, ~video_bits, i); // render char/scanline
// else
// display_bit_80col(renderer, x, y, video_bits, i); // render char/scanline
private:
uint8_t videx_rom[0x400]; // 0x0400 at C800-CBFF
uint8_t videx_chars[0xfff]; // 0x0-0x7ff rom 1 | 0x800-0xfff rom2 character rom (12x8) Matrix)
uint8_t videx_vram[2048]; // 0x0800 at CC00-CDFF in 4 banks of 0x1FF
// internal variables
int videx_bankSLOT, videx_regvalSLOT; // active memory bank, selected register
unsigned char videx_regSLOT[17];// registers of the CRT-controller
//int videx_oldcursorSLOT; // old cursor position
//int videx_upperSLOT, videx_lowerSLOT; // cursor size
// Registers
// register r/w normal value Name
// 00: w 7B Horiz. total
// 01: w 50 Horiz. displayed
// 02: w 62 Horiz. sync pos
// 03: w 29 Horiz. sync width
// 04: w 1B Vert. total
// 05: w 08 Vert. adjust
// 06: w 18 Vert. displayed
// 07: w 19 Vert. sync pos
// 08: w 00 Interlaced
// 09: w 08 Max. scan line
// 10:0A w C0 Cursor upper
// 11:0B w 08 Cursor lower
// 12:0C w 00 Startpos Hi
// 13:0D w 00 Startpos Lo
// 14:0E r/w 00 Cursor Hi
// 15:0F r/w 00 Cursor Lo
// 16:10 r 00 Lightpen Hi
// 17:11 r 00 Lightpen Lo
// The registers are addressed as follows:
// To write To read
// LDA #$ LDA #$
// STA $C0B0 STA $C0B0
// LDA #$ LDA $C0B1
// STA $C0B1
public:
int getC0SLOTX(int adr)// 0x0400 at C800-CBFF
int value = 0x00;
//define current memory bank
videx_bankSLOT = (adr & 0x000c) >> 2;
if (adr & 0x0001)
// get current register value
value = videx_regSLOT[videx_regvalSLOT];
else
// define current register
videx_regvalSLOT = value;
return value;
void putC0SLOTX(int adr, int value)// 0x0400 at C800-CBFF
if (adr & 0x0001)
// set current register value
videx_regSLOT[videx_regvalSLOT] = value;
//10:0A Cursor upper //11:0B Cursor lower
if ((videx_regvalSLOT == 10) || (videx_regvalSLOT == 11))
modifySLOT();
//14:0E Cursor Hi //15:0F Cursor Lo
if ((videx_regvalSLOT == 14) || (videx_regvalSLOT == 15))
cursorSLOT();
//13:0D Startpos Lo
if (videx_regvalSLOT == 13)
redrawSLOT();
//12:0C Startpos Hi
else
// IOSEL READS ROM
// when reading using iosel, adds bit at A9
uint8_t getRomIoSel(int addr) {
addr |= 0b1000000000;
if (addr < 0x0400) return videx_rom[addr & 0x03ff];
return 0;
// Read Video Memory using position x, y
int8_t getCSLOTXX(int col, int row) {
int vstart = ((videx_regSLOT[12] << 8) | videx_regSLOT[13]);
int vcursor = ((videx_regSLOT[14] << 8) | videx_regSLOT[15]);
int vaddr = (((row * 80) + col) + vstart) % 0x800;
return videx_vram[vaddr];
// Read Character Rom (Char/scanline)
int8_t getVideoBits(int8_t keycode, int line) {
return videx_chars[keycode * 16 + line];
// Is cursor at defined x, y?
bool isCursorPosition(int col, int row) {
return vcursor == (((row * 80) + col) + vstart);
// IOSTB - Get Rom or VRam
int getSLOTC8XX(int adr)
if (adr < 0x0400) // Rom is at 0x0-0x3ff
return(videx_rom[adr & 0x03ff]);
else
// VRAM is at 0x600-0x7FF
// VRAM has 0x0800 at CC00-CDFF divided in 4 banks of 0x1FF
if (adr < 0x0600)
return(videx_vram[(adr & 0x01ff) + videx_bankSLOT * 0x0200]);
else //600 (or CE00-CF00)
return(0);
// IOSTB - set VRam
void putSLOTC8XX(int adr, int value)
if ((adr >= 0x0400) && (adr < 0x0600))
int vadr;
vadr = (adr & 0x01ff) + videx_bankSLOT * 0x0200;
videx_vram[vadr] = value;
//drawSLOT(vadr, value); // ignored
void card_videx_init() {
FILE *g;
int i;
int value, bits, crow, ccol;
// Read videx rom
printf("Loading rom: videx_firmware.rom\n");
g = fopen("videx_firmware.rom", "r");
if (g == 0)
fprintf(stderr, "can't find 'videx_firmware.rom'.\n");
exit(1);
fread(videx_rom, 1, 0x0400, g);
fclose(g);
// Read videx character rom
printf("Loading rom: videx_chars.rom\n");
g = fopen("videx_chars.rom", "r");
if (g == 0)
fprintf(stderr, "can't find 'videx_chars.rom'.\n");
exit(1);
fread(videx_chars, 1, 0x1000, g);
fclose(g);
// initializing registers
videx_bankSLOT = 0;
videx_regvalSLOT = 0;
videx_regSLOT[0] = 0x7b;
videx_regSLOT[1] = 0x50;
videx_regSLOT[2] = 0x62;
videx_regSLOT[3] = 0x29;
videx_regSLOT[4] = 0x1b;
videx_regSLOT[5] = 0x08;
videx_regSLOT[6] = 0x18;
videx_regSLOT[7] = 0x19;
videx_regSLOT[8] = 0x0;
videx_regSLOT[9] = 0x8;
videx_regSLOT[10] = 0xc0;
videx_regSLOT[11] = 0x8;
videx_regSLOT[12] = 0x0;
videx_regSLOT[13] = 0x0;
videx_regSLOT[14] = 0x0;
videx_regSLOT[15] = 0x0;
videx_regSLOT[16] = 0x0;
videx_regSLOT[17] = 0x0;
//videx_upperSLOT = 0;
//videx_lowerSLOT = 8;
//videx_oldcursorSLOT = 0;
for (i = 0; i < 2048; i++)
videx_vram[i] = i & 0xff;
void drawSLOT(int adr, int value)
int sadr, crow, ccol;
// update memory pixmap
//XCopyArea(display, charsetSLOT, memorySLOT, gc, 8 * value, 0, 8, 12, adr * 8, 0);
// update screen
sadr = (0x800 + adr - 256 * videx_regSLOT[12] - videx_regSLOT[13]) & 0x7ff;
crow = sadr / 80;
ccol = sadr % 80;
//printf("FRAMEBUFFER [W] %d x %d = %02X {%02x}\n", ccol, crow, value, ((crow * 80) + ccol) * 8 );
//XCopyArea(display, charsetSLOT, wSLOT, gc, 8 * value, 0, 8, 12, ccol * 8, crow * 12);
void cursorSLOT()
int sadr, newcursor, crow, ccol;
// remove old cursor
drawSLOT(videx_oldcursorSLOT, videx_vram[videx_oldcursorSLOT]);
// update cursor
newcursor = (256 * videx_regSLOT[14] + videx_regSLOT[15]) & 0x7ff;
sadr = (0x800 + newcursor - (256 * videx_regSLOT[12] + videx_regSLOT[13])) & 0x7ff;
crow = sadr / 80;
ccol = sadr % 80;
//XFillRectangle(display, wSLOT, xgcSLOT, ccol * 8, crow * 12 + upperSLOT, 7, lowerSLOT - upperSLOT);
//XFlush(display);
// remember old cursor
videx_oldcursorSLOT = newcursor;
void redrawSLOT()
sadr = (256 * videx_regSLOT[12] + videx_regSLOT[13]) & 0x7ff;
for (crow = 0; crow < 24; crow++)
ccol = sadr + 80;
if (ccol > 0x800)
ccol &= 0x7ff;
//printf("%d x %d\n", ccol, crow);
//XCopyArea(display, memorySLOT, wSLOT, gc, 8 * sadr, 0, 8 * (80 - ccol), 12, 0, crow * 12);
//XCopyArea(display, memorySLOT, wSLOT, gc, 0, 0, 8 * ccol, 12, 8 * (80 - ccol), crow * 12);
else {
//XCopyArea(display, memorySLOT, wSLOT, gc, 8 * sadr, 0, 8 * 80, 12, 0, crow * 12);
sadr = ccol;
cursorSLOT();
void modifySLOT()
int val;
// set upper cursor bound
val = videx_regSLOT[10] & 0x7f; // remove blinking-flag
if (val)
while ((val & 0x40) == 0)
videx_upperSLOT++;
val = val << 1;
// set lower cursor bound
videx_lowerSLOT = 12;
val = videx_regSLOT[11];
if (val)
while ((val & 0x01) == 0)
videx_lowerSLOT--;
val = val >> 1;
// if the setting is ridiculous
if (videx_upperSLOT >= videx_lowerSLOT)
// draw new cursor
cursorSLOT();
