New Tibbo IDE (TIDE) release 5.03.03 includes a Tibbo OS (TiOS) Simulator. The Simulator implements a virtual TiOS device incorporating virtual Ethernet interface, virtual EEPROM, virtual flash memory, virtual MD button, buzzer, and status LEDs, as well as virtual LCD and keypad.
The Simulator makes it possible to test-drive TIDE and TiOS, as well as run and debug Tibbo BASIC and C applications, without having to commit to a purchase of a physical Tibbo device.
The Simulator can be found here: WINDOWS START > Tibbo > Tibbo IDE > TiOS Simulator. You can also start TiOS Simulator from within TIDE: Debug > Start TiOS Simulator.
Once the Simulator is running, it appears in the Device Explorer as any other TiOS device would. To write an app for the Simulator, select the SIMULATOR platform and set the Simulator as the debug target.
TIDE 5.03.03 is distributed with a number of test projects written specifically for TiOS Simulator. You can find them here: (My) Documents\TIDE\Samples.
Dmitry Slepov
