thingSoC "Grovey" on Crowd Supply
oshparkoshpark wrote 01/26/2017 at 20:22 • • 2 min read • Like
thingSoC is an Open Source socket system for IoT development and has just launched a new Crowdy Supply campaign:
thingSoC “Grovey”
Build any IoT or Networked device you can imagine!
c24rwnwveaaa4cm
The thingSoC Grovey! platform gives you the freedom to choose from hundreds of existing sensors, actuators, and radios to quickly create new electronic systems, in plug together configurations that were not possible before. Easily mix together different CPUs, Radios, and Peripherals, like Servos, Motors, Relays, Sound and Lights, and then program them in your choice of Integrated Development Environments (IDE).
https://www.crowdsupply.com/patternagents-llc/thingsoc-grovey
The thingSoC Grovey! series combines access to the Seeedstudio Grove system, and the Mikrobus “Click” system, to give you the widest selection of radios, sensors, and actuators available today.
The thingSoC Grovey Series files are available on GitHub:
Like
