Yin Zhong designed this solution to use high-end studio headphones with his computer:
Making Myself a USB DAC + Headphone Amp
I need a DAC for my AKG K702. However, the more I looked at commercially available a.k.a. “audiophile” products, the more snake oil I smell. So even before I ordered my CEntrance DACPort Slim, I was already looking into how I can reinventing the wheel
I use OSHPark for prototyping PCBs. I decided to use their 4-layer FR-408 stackup simply for an un-broken ground layer. Turns out that the analog signals can easily fit on the top layer, so I allocated the power layer to the negative rail, and the bottom layer to positive rails.
The DAC + Filter module works! It produces reasonably clean line-level audio signal as expected.
oshpark
