I've been doing a lot of work and revision to the #Aquariumatic project as of late.
Over the no the the project has evolved from being a wired, tethered, limited system to being an open, expandable wireless lot platform with so many potential uses.
With this in mind I am contemplating a rethink on how I document this project.
I am going to archive the current page, tidy up its contents and use it to reflect on how the project has progressed between the versions and how it has made it to this point.
I am then going to create a new project, dedicated to the IoT Controller/Hub setup, then create a new project page for the Aquariumatic variation on the setup, in addition to new project page for each and every variation upon the platform.
To go with this I am going to rewrite all code currently used in the project to reflect its new structure, with the Aquariumatic-specific code to be rewritten as an add-in module.
Watch this space!
@davedarko any name suggestions for the core modules are greatly welcomed:-D
