1. Basic principles and characteristics of stepper motors
A stepper motor is a precision motor that can accurately control position according to a preset number of steps. The working principle of a stepper motor is to use magnetic field rotation to control the position and speed of the rotor. It consists of stator, rotor, drive circuit and sensor. Whenever the drive circuit gives a pulse signal, the rotor will rotate at a certain angle according to the set number of steps. Stepper motors have the advantages of precise control and high positioning accuracy, and are widely used in robots, CNC machine tools, electronic equipment and other fields.
2. Can stepper motors be powered by batteries?
The answer is yes. Stepper motors can be powered by batteries, but you need to pay attention to whether the voltage and current of the battery meet the requirements of the stepper motor. The voltage and current of stepper motors are generally relatively large, so a suitable battery needs to be selected for power supply. At the same time, the stepper motor needs to be connected to the drive circuit to work properly, so the drive circuit needs to be selected to match the battery to ensure that the stepper motor can work properly.
![](https://cdn.hackaday.io/images/3782971717656088831.png)
3. Precautions when using battery power supply for stepper motors
3.1 Choose the right battery: Stepper motors require relatively large voltage and current, so you need to choose a high-capacity, high-power battery for power supply. At the same time, it is necessary to select a suitable protection circuit for the battery to prevent battery over-discharge, over-charge, over-current and other problems.
3.2 Choose the appropriate drive circuit: Stepper motors require a drive circuit to work properly, and you need to choose a stable and reliable drive circuit. The power supply of the drive circuit needs to match the battery to ensure that the stepper motor can work properly.
3.3 Control power supply: Stepper motors require a stable and reliable control power supply to ensure that the position and speed of the stepper motor can be accurately controlled.
3.4 Avoid over-discharging the battery: Over-discharging will greatly shorten the life of the battery, and may cause battery short circuit, leakage and other problems. Therefore, a protection circuit needs to be used to control the over-discharge of the battery so as not to affect the normal operation of the stepper motor.
In short, stepper motors can be powered by batteries, but attention needs to be paid to the selection of appropriate batteries and drive circuits to ensure the normal operation of the stepper motor.
