Advantages and disadvantages of LED street lamp holders
torr45838torr45838 wrote 04/08/2024 at 01:59 • 4 min read • Like
Principle of LED Street Lamp Cap
The integrated design of the heat sink and lamp housing of the LED street lamp head ensures that the LED is directly connected to the shell and dissipates heat through the shell's cooling wings and air convection, fully ensuring the LED street lamp's 50000 hour service life. Based on working 12 hours a day, its lifespan is also over 10 years, and maintenance costs are extremely low; The lamp housing is made of aluminum alloy die-casting, which can effectively dissipate heat, prevent water and dust. The surface of the lamp has been treated with UV resistance and corrosion resistance, and the overall lamp meets the IP65 standard;
The design adopts a single elliptical reflection cavity combined with a spherical solitary surface to control the light emitted by the LED within the required range, improving the uniformity of the lighting effect and the utilization of light energy, and highlighting the energy-saving advantages of LED street lights. Compared to traditional sodium lamps, it can save more than 60% of electricity.
The advantages of LED street lamp heads
Disadvantages of LED street lamp heads
Like
Rich text editor
