DESCRIPTION
Are you an IoT enthusiast or a developer looking for a versatile development board that meets all your power requirements? Do you need a solution that can handle anything from wall outlet-powered projects to solar and battery-dependent systems? If so, the OBJEX Link S3LW is the answer to your needs.
Imagine a development board that not only offers extreme low-power operation but can also deliver high-power functionality up to 100 W. This level of flexibility is crucial for a wide range of IoT projects, and it's exactly what the OBJEX Link S3LW delivers. With its six sets of header connectors, you have granular control over the power supply to individual components, making it easier than ever to tailor your setup to your project's specific needs.
The OBJEX Link S3LW stands out with its robust wireless capabilities. Integrated with 2.4 GHz, 802.11 b/g/n Wi-Fi, and Bluetooth 5 (LE) connectivity, it supports long-range communication options that are ideal for LoRa/LoRaWAN solutions. This ensures that your projects remain connected, no matter the distance.
What about compatibility? Whether you're working with ESP-IDF, Arduino, PlatformIO, MicroPython, or Rust, the OBJEX Link S3LW seamlessly fits into your workflow. This makes it a go-to choice for developers who value flexibility and ease of use in their development process.
At the heart of the OBJEX Link S3LW is the OBJEX ELPM-S3LW module, designed with a focus on battery-powered and energy-harvesting applications. Leveraging the ESP32-S3FN8 and SX1262 chips, this module excels in minimizing power consumption, offering a deep stop mode that draws as little as 1-100 nA. This makes it an excellent choice for industrial applications and devices requiring high energy efficiency.
Moreover, for those who need different specifications, variants of both OBJEX Link S3 and OBJEX ELPM-S3 are available without LoRa.
In summary, the OBJEX Link S3LW is not just another development board; it's a comprehensive solution designed to meet the diverse and demanding needs of modern IoT projects. Whether you're building an energy-efficient sensor network or a high-powered communication device, this board provides the tools you need to succeed. So, why settle for less when you can have the flexibility, power, and connectivity of the OBJEX Link S3LW? Dive into your next IoT project with confidence, knowing you have the best foundation possible.
Crowdsupply page: https://www.crowdsupply.com/objex/objex-link-s3lw
