ANTIRTOS: blink dozens LEDs with easy. Chained function approach
aleksei-tertychnyiAleksei Tertychnyi wrote 10/05/2024 at 11:24 • • 2 min read • Like
Some example how to blink multiple LEDs differenly  with only one function queue with chained functions approach. Do not need to warry about any LED blinking any more :)
#include <antirtos.h>
typedef
struct pinOut { // structure (index - pin number, logic - 1/0 = ON/OFF)
  int index;
  int logic;
  int period;
} pinout ;
del_fQP<pinout> Q1(9); // maximum 9 function pointers with parameters in queue
void writePin(pinout cmd) { // write a pin logic
  digitalWrite(cmd.index, cmd.logic);
  if (cmd.logic) // inverting logic
    cmd.logic = LOW;
  else
    cmd.logic = HIGH;
  Q1.push_delayed(writePin, cmd, cmd.period); //add this function into a queue again
void setup() {
  // put your setup code here, to run once:
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  //timet setup
  TCCR1A = 0x00;  //Normal Mode
  TCCR1B = 0x00;  //TC1 is OFF
  TCNT1 = 0;
  OCR1A = 6250;  //0.1s delay; prescaler 256
  bitSet(TIMSK1, OCIE1A);   //local intterupt is active
  TCCR1B |= bit(CS12);   //Start TC1 with prescale 256
  Q1.push_delayed(writePin, {5, HIGH, 5}, 5);   // period 1 sec.
  Q1.push_delayed(writePin, {6, HIGH, 10}, 10); // period 2 sec.
  Q1.push_delayed(writePin, {7, HIGH, 20}, 20); // period 4 sec.
  Q1.push_delayed(writePin, {8, HIGH, 40}, 40); // period 8 sec.
  Q1.push_delayed(writePin, {9, HIGH, 80}, 80); // period 16 sec.
  Q1.push_delayed(writePin, {10, HIGH, 160}, 160); // period 32 sec.
  Q1.push_delayed(writePin, {11, HIGH, 320}, 320); // period 64 sec.
  Q1.push_delayed(writePin, {12, HIGH, 640}, 640); //period 128 sec.
void loop() {
  // put your main code here, to run repeatedly:
  Q1.pull(); // pull from the queue
ISR(TIMER1_COMPA_vect) // timer interrupt ticks one per 0.1 sec
  TCNT1 = 0;
  OCR1A = 6250;
  Q1.tick(); // execute tick method for make delayed functionality works
 Try it youself here: wokwi
Like
