Yes, the torque stop function can be achieved by adjusting the torque setting in the closed loop when the servo motor is running.
1. Working principle of servo motor
A servo motor is a motor that converts electrical energy into mechanical motion. Unlike ordinary motors, it monitors the motion state in real time through feedback devices such as encoders, and the control circuit controls the motor more accurately.
The main working principle of the servo motor is: the control circuit reads the feedback signal, compares it with the target position, calculates the error, and sends the control signal to the motor so that it can move according to the preset motion trajectory.
2. The principle of setting the torque stop function
During the operation of the servo motor, the torque stop function needs to be set in many application scenarios to ensure that the device can stop moving more accurately.
The principle of achieving torque stop is: in most cases, there is a torque limiter inside the servo controller. By adjusting the torque setting in the closed loop, the purpose of stopping the motor can be achieved after reaching a certain torque.
However, it should be noted that if the set torque is too small, it may affect the normal operation of the device, so it needs to be flexibly set according to the actual application situation.
3. Advantages and application scenarios of servo motors
Servo motors have the following advantages:
1. High precision: Due to the use of closed-loop control, the servo motor can monitor its own motion state in real time and accurately control it, ensuring higher accuracy and precision.
2. Fast response speed: Due to the support of a large number of special electronic technology equipment inside the servo motor, it can achieve fast response in an instant, thereby improving work efficiency.
3. Adaptable to a variety of application scenarios: Servo motors are widely used and can be applied to equipment in various industries, such as CNC machine tools, punching machines, robots, etc.
In summary, setting the torque stop function can effectively ensure the stability and safety of the equipment, and is widely used and easy to implement in the operation of servo motors.
