Getting Started with the LD2410C mmWave Presence Sensor
peter-scargillPeter Scargill wrote 10/12/2025 at 07:15 • 1 min read • Like
The LD2410C is a compact mmWave radar sensor capable of detecting presence and motion in a room. I’ve put together a “first steps” guide showing wiring, setup, and configuration using the manufacturer’s web-based tool, along with a short demo video.
This is ideal for Home Assistant, ESPHome, or general DIY automation projects. If you’re curious about mmWave detection or want to experiment with radar-based presence sensors, the guide walks you through the basics and shares initial observations.
Check it out here: https://tech.scargill.net/ld2410c-first-steps/
Like
