Vibe Coding Assistant - AI Driven Program Generation Without Prompting
harvosHarvOS wrote 10/12/2025 at 13:32 • • 2 min read • Like
Vibe Coding Assistant: Building Software Without Coding or Prompt Engineering
Intro
Most of us have seen the rise of NoCode and AI-assisted coding tools. NoCode platforms let you wire workflows visually, while AI assistants like Copilot generate code from natural language. Both are useful, but both have drawbacks:
Vibe Coding Assistant takes another approach: a GUI driven project design. The system generates your application automatically. No drag-and-drop logic, no hand-crafted prompts — just structured input → runnable code.
How It Works
Vibe Coding Assistant is written in Java and uses the GitHub Copilot CLI under the hood.
The workflow is simple:
  1. Fill in the GUI: Define your app using the GUI.
  2. Auto-Prompt Generation: The tool creates an AI prompt internally.
  3. Code Generation: GitHub Copilot CLI generates source code.
  4. Compile & Run: You get a working program out-of-the-box.
Requirements
On first launch, dependencies are automatically installed.
Why It’s Interesting
Normally, generating code via AI means iterating over prompts until it works. Vibe Coding Assistant removes that step entirely.
Think of it as a code generator for non-programmers that’s still hackable enough for devs. Prototype an idea fast, then tweak the generated code as needed.
Potential use cases:
Current State
The project can already:
Limitations:
Roadmap & Contribution
The next big step is improving automatic prompt generation. Contributions are welcome in areas like:
If you’re into AI + open source hacking, this is a good project to explore. Repo is here: GitHub – decipher2k/VibeCodingAssistant
Philosophy
The name says it: Vibe Coding. Programming should feel less like debugging syntax and more like catching a creative flow. The assistant handles the translation from idea → prompt → code.
Conclusion
Vibe Coding Assistant isn’t magic, but it’s a fresh take on AI-powered programming. By removing both coding and prompt engineering, it could bring software creation to new audiences — while still offering developers a shortcut for boring tasks.
👉 Check it out on GitHub, and if you like the vibe, contribute!
Discussion for Hackaday readers: Would you trust AI-generated code as part of your code? Or is this more of a prototyping tool until the tech matures?
Like
