How to Interface the 74HC595 Serial Shift Register with a PIC16F877A (Drive 8+ LEDs with 3 Pins)
Want to drive a bunch of LEDs (or any digital outputs) but you’re running out of GPIOs on the PIC16F877A? The 74HC595 serial-in/parallel-out (SIPO) shift register is the classic fix: you clock data in using just DATA, CLOCK, and LATCH lines, and it presents eight stable outputs on Q0–Q7. You can also daisy-chain more ‘595s to get 16, 24, 32… outputs with the same three pins.
Below is a complete, hands-on guide with wiring, timing, pitfalls, and two code options (bit-banged I/O and hardware SPI) for both MikroC PRO for PIC and MPLAB XC8.
What You’ll Learn
What the 74HC595 does and when to use it
Exact connections between PIC16F877A and 74HC595
Timing (CLOCK vs LATCH) and bit order
Clean, reusable send-byte routines (bit-bang & SPI)
Daisy-chaining two or more 74HC595s
Troubleshooting tips and common mistakes
Why use a 74HC595?
Microcontrollers have limited GPIO. The 74HC595 lets you:
Save pins: 3 control pins → 8 outputs (and more if chained)
Scale easily: add another ‘595 for +8 outputs without using more MCU pins
Keep outputs stable: the outputs don’t change until you hit LATCH, so you avoid flicker/glitches
Typical uses: LED bars/matrices, 7-segment displays (single or multiplexed), relays, simple digital control lines.
IC Overview (74HC595)
Type: SIPO (Serial-In / Parallel-Out), 8-bit
Voltage: 2–6 V (works great at 5 V with the PIC16F877A)
Two internal registers:
Shift register receives serial data on DS with SH_CP (shift clock)
Storage (latch) register updates outputs Q0–Q7 on rising edge of ST_CP (latch clock)
⚠️ Naming you’ll see in datasheets:
- DS = Serial Data
- SH_CP = Shift Clock (sometimes “SRCLK”)
- ST_CP = Storage/Latch Clock (sometimes “RCLK”)
- OE̅ (active-LOW Output Enable)
- MR̅ (active-LOW Master Reset)
- Q7′ (serial out for daisy-chain)
Pin Summary (16 pins)
| Pin | Name | Function / Notes |
| 14 | DS | Serial data in |
| 11 | SH_CP | Shift clock (data sampled on rising edge) |
| 12 | ST_CP | Latch clock (outputs updated on rising edge) |
| 13 | OE̅ | Output enable (active LOW). Tie to GND to always enable. |
| 10 | MR̅ | Master reset (active LOW). Tie to VCC for normal operation. |
| 9 | Q7′ | Serial out to next ‘595’s DS (for chaining) |
| 1–7,15 | Q0–Q7 | Parallel outputs |
| 8 | GND | Ground |
| 16 | VCC | +5 V |
✅ Common correction: A frequently cited PISO partner IC is 74HC165, not 74HC156.
Hardware You Need
PIC16F877A + 5 V supply
74HC595 (1 or more)
8× LEDs + 8× current-limit resistors (e.g., 330 Ω when using 5 V)
8 MHz or 20 MHz crystal + two 22 pF capacitors (PIC16F877A has no internal oscillator)
Breadboard & wires
Wiring (Single 74HC595N + 8 LEDs)
PIC16F877A → 74HC595 (recommended pins):
RC1→ DS (pin 14) – Data -
RC0→ SH_CP (pin 11) – Shift clock -
RC2→ ST_CP (pin 12) – Latch clock -
OE̅ (pin 13) → GND (always enabled)
MR̅ (pin 10) → VCC (no resets)
VCC (pin 16) → +5 V
GND (pin 8) → GND
Outputs & LEDs:
Q0–Q7 (pins 15,1–7) → LED → resistor → GND (or VCC, depending on your polarity; just be consistent)
💡 If you ever want to blank all outputs in one shot, route OE̅ to a PIC pin instead of GND and set it HIGH to disable outputs.
Timing in One Picture (conceptually)
Put the next data bit on DS
Pulse SH_CP (rising edge) → bit shifts in
Repeat for 8 bits (MSB-first or LSB-first; just be consistent)
Pulse ST_CP (rising edge) → all Q0–Q7 update at once
Bit Order (important!)
You can shift MSB-first or LSB-first. Choose one and use it everywhere (your patterns must match). In the code below, we’ll do LSB-first because it’s simple for LED sequences; I’ll show you how to flip it.
| Part Number | Description | Orderable / Packaging | Function | Temp Range | Mounting | Package & Width | Package Code | Notes / Status |
| SN74HC595DBR | IC SR TRI-STATE 8BIT 16-SSOP | Tape & Reel (TR) | Serial to Parallel, Serial | -40°C ~ 85°C | Surface Mount | 16-SSOP (0.209″, 5.30mm) | 16-SSOP | — |
| SN74HC595ADBR | IC SR TRI-STATE 8BIT 16-SSOP | Tape & Reel (TR) | Serial to Parallel, Serial | -40°C ~ 85°C | Surface Mount | 16-SSOP (0.209″, 5.30mm) | 16-SSOP | — |
| CD74HC595SM96 | IC SR TRI-STATE 8BIT 16-SSOP | Tape & Reel (TR) | Serial to Parallel, Serial | -55°C ~ 125°C | Surface Mount | 16-SSOP (0.209″, 5.30mm) | 16-SSOP | Extended temp |
MikroC PRO for PIC (Bit-Banged I/O)
Set your project to HS oscillator and match the crystal you use (8 MHz example below).
// MikroC PRO for PIC
// PIC16F877A @ 8 MHz (HS)
// Simple bit-bang driver for 74HC595 (LSB-first)
sbit DATA_pin at PORTC.B1; // DS
sbit CLOCK_pin at PORTC.B0; // SH_CP
sbit LATCH_pin at PORTC.B2; // ST_CP
void pulse_clock() { CLOCK_pin = 1; Delay_us(2); CLOCK_pin = 0; Delay_us(2);
void latch_update() { LATCH_pin = 1; Delay_us(2); LATCH_pin = 0;
// Send one byte, LSB-first
void shiftOutLSB(unsigned char val) { unsigned char i; for (i = 0; i < 8; i++) { DATA_pin = (val >> i) & 0x01; pulse_clock(); } latch_update();
void main() { TRISC.B0 = 0; // CLOCK TRISC.B1 = 0; // DATA TRISC.B2 = 0; // LATCH CLOCK_pin = 0; DATA_pin = 0; LATCH_pin = 0;
while(1) { // Walk a single '1' across Q0..Q7 for (unsigned char b = 0; b < 8; b++) { shiftOutLSB(1 << b); Delay_ms(150); } // All off shiftOutLSB(0x00); Delay_ms(200); // All on shiftOutLSB(0xFF); Delay_ms(200); }
MSB-first version (swap the loop body):
void shiftOutMSB(unsigned char val) { char i; for (i = 7; i >= 0; i--) { DATA_pin = (val >> i) & 0x01; pulse_clock(); } latch_update();
MPLAB XC8 (Bit-Banged I/O)
Set configuration bits for HS crystal and match _XTAL_FREQ to your crystal (8 MHz shown). If you use 20 MHz, set _XTAL_FREQ 20000000 and delays will scale.
// MPLAB XC8, PIC16F877A @ 8 MHz (HS)
#include <xc.h>
#define _XTAL_FREQ 8000000
// CONFIG (adjust to your project as needed)
#pragma config FOSC = HS, WDTE = OFF, PWRTE = OFF, BOREN = ON, LVP = OFF, CPD = OFF, WRT = OFF, CP = OFF
#define DATA_pin RC1 // DS
#define CLOCK_pin RC0 // SH_CP
#define LATCH_pin RC2 // ST_CP
void pulse_clock(void) { CLOCK_pin = 1; __delay_us(2); CLOCK_pin = 0; __delay_us(2);
void latch_update(void) { LATCH_pin = 1; __delay_us(2); LATCH_pin = 0;
// LSB-first
void shiftOutLSB(unsigned char val) { for (unsigned char i = 0; i < 8; i++) { DATA_pin = (val >> i) & 0x01; pulse_clock(); } latch_update();
void main(void) { TRISC0 = 0; // CLOCK TRISC1 = 0; // DATA TRISC2 = 0; // LATCH RC0 = 0; RC1 = 0; RC2 = 0;
while(1) { for (unsigned char b = 0; b < 8; b++) { shiftOutLSB(1 << b); __delay_ms(150); } shiftOutLSB(0x00); __delay_ms(200); shiftOutLSB(0xFF); __delay_ms(200); }
Using the PIC’s Hardware SPI (MSSP) — Faster & Cleaner
The PIC16F877A has an MSSP module that can operate as SPI Master. This lets you blast out a byte with one register write—much faster and lower CPU overhead than bit-banging.
Connections (SPI Master):
RC3/SCK→ SH_CP -
RC5/SDO→ DS -
A spare GPIO (e.g.,
RC2) → ST_CP (latch) -
OE̅ → GND, MR̅ → VCC
MPLAB XC8 (SPI example, MSB-first by hardware):
#include <xc.h>
#define LATCH_TRIS TRISC2
#define LATCH_LAT RC2
void spi_init(void) { // SDO=RC5 output, SCK=RC3 output TRISC3 = 0; // SCK TRISC5 = 0; // SDO LATCH_TRIS = 0; LATCH_LAT = 0;
// SPI Master, Fosc/16, CKP=0, CKE=1 (Mode 0,0) SSPSTAT = 0b01000000; // CKE=1 SSPCON = 0b00100001; // SSPEN=1, CKP=0, Fosc/16
void latch_update(void) { LATCH_LAT = 1; __delay_us(2); LATCH_LAT = 0;
void shiftOutSPI(unsigned char val) { SSPBUF = val; // start transfer while(!SSPSTATbits.BF); // wait done latch_update(); // update outputs
void main(void) { spi_init();
while(1) { for (unsigned char b = 0; b < 8; b++) { // If you want LSB-first behavior visually on Q0..Q7, // you can reverse bits before sending (optional). unsigned char v = (1 << b); // send directly (MSB-first over the wire; 74HC595 doesn't care as long as you're consistent) shiftOutSPI(v); __delay_ms(120); } shiftOutSPI(0x00); __delay_ms(200); shiftOutSPI(0xFF); __delay_ms(200); }
📝 Notes
- SPI mode CKP=0, CKE=1 (Mode 0,0) is safe for the 74HC595; data is sampled on SCK rising edge.
- If your display pattern looks reversed, swap to a bit-reversed lookup before sending or choose LSB/MSB-first consistently across your project.
Daisy-Chaining Two or More 74HC595s
To get 16, 24, 32… outputs:
First ‘595 Q7′ (pin 9) → next ‘595 DS (pin 14)
Share CLOCK (SH_CP) and LATCH (ST_CP) to all chips
Send N bytes back-to-back (last byte you send ends up on the first ‘595 in the chain), then one LATCH pulse to update all.
Example (bit-bang, 2 chips):
void shiftOut2Bytes(unsigned char b1, unsigned char b2) { // Send the byte destined for the furthest chip first shiftOutLSB(b2); // goes to second chip shiftOutLSB(b1); // then first chip // shiftOutLSB already calls latch_update().
Common Mistakes & Troubleshooting
SH_CP vs ST_CP swapped:
SH_CP is the shift clock; ST_CP is the latch clock. If LEDs flicker or show partial updates, double-check this.
No current-limiting resistors: LEDs may burn out or draw too much current from Q pins. Use 220–470 Ω per LED.
OE̅ left floating: Tie to GND (or drive from MCU). Floating can randomly disable outputs.
MR̅ not tied to VCC: If left floating/LOW, the register keeps resetting → no output.
Wrong delays / oscillator setting:
_XTAL_FREQmust match your crystal in XC8; otherwise delays are wrong. -
Bit order mismatch: If your LED pattern looks backward, you’re sending MSB-first while your mental model is LSB-first (or vice versa). Standardize and stick to it.
Supply & decoupling: Add a 0.1 µF ceramic close to the ‘595 VCC pin. Long wires benefit from a bulk cap (e.g., 10 µF).
Extending to 7-Segment and LED Matrices
Single 7-segment (static): one ‘595 is enough; map segments to Q0–Q7.
4-digit multiplexed: use one ‘595 for segments and a transistor array (or another ‘595 with PNP/NPN drivers) for digit selects.
8×8 matrix: two ‘595s—one for rows, one for columns—plus multiplexing logic in code.
