Modbus CRC using an STM32 controller
oaolsenO.A.Olsen wrote 10/26/2025 at 20:10 • • 1 min read • Like
The Modbus RTU protocol calls for the calculation of the CRC for each message transmitted.
From the perspective of an STM32 controller the CRC calculation properties are  :
  hcrc.Init.DefaultPolynomialUse = DEFAULT_POLYNOMIAL_DISABLE;
  hcrc.Init.DefaultInitValueUse = DEFAULT_INIT_VALUE_ENABLE;
  hcrc.Init.GeneratingPolynomial = 32773;
  hcrc.Init.CRCLength = CRC_POLYLENGTH_16B;
  hcrc.Init.InputDataInversionMode = CRC_INPUTDATA_INVERSION_BYTE;
  hcrc.Init.OutputDataInversionMode = CRC_OUTPUTDATA_INVERSION_ENABLE;
  hcrc.InputDataFormat = CRC_INPUTDATA_FORMAT_BYTES;
 In hexadecimal notation the polynomial value is 0x8005. Equivalent to using  this polynomial in the MX configurator : X15+X2+X0. The CRC can be calculated by the hardware CRC block by using this function:
uint16_t hwCalcCrc(uint8_t *d, int bytes)
    int i;
    hcrc.Instance->CR |= 1;// Reset the calculator
    for (i=0; i<bytes; i++)
     *(__IO uint8_t *)(__IO void *)(&hcrc.Instance->DR) = d[i];
    return hcrc.Instance->DR;
 The C pre-processor  replaces volatile for the __IO macro. So, this is a trick to keep  the compiler from optimizing out repeated writes to the same static register.
// WORKS:
// DOESN'T WORK
hcrc.Instance->DR = d[i];
Test message:
The CRC of
[ 0x01, 0x10, 0x00, 0x00, 0x00, 0x01, 0x02, 0xAA, 0xAA]
 is 0x8f58.
Like
