VS Code Build Lights: Broadcasting Success And Failure Over UDP
sudarshan-patilSudarshan patil wrote 02/27/2026 at 18:41 • • 4 min read • Like
Make Your Editor Talk To Your Hardware
Most developers rely on on-screen notifications to know whether a build succeeded or failed. But if you’re working across multiple monitors, running CI pipelines, or doing embedded work with long build times, you sometimes want something more physical — like a blinking LED, a buzzer, a display, or even a small dashboard that lights up when things break.
So I built a simple tool that lets VS Code broadcast UDP messages every time a task completes — success or failure — allowing any hardware on your network to react instantly.
This lets you create your own build lights, IoT indicators, or automation triggers with almost zero setup.
Repo: https://github.com/sdrshnptl/notifybuildresult
🛠 What It Does
The extension watches VS Code tasks. Whenever a task ends, it sends a UDP broadcast packet to your LAN.
Example payload:
{  "task": "Build Firmware",  "status": "success"
Anything that can listen on UDP (ESP32, Raspberry Pi, Node.js, Python, Arduino, home automation, etc.) can act on it.
This means you can build:
⚙️ Why UDP?
UDP broadcast is:
If your LAN has devices listening on port 10203, they will instantly react to VS Code builds.
UDP is perfect here — even CI systems sometimes use beacons to announce events.
🔧 How It Works Internally
The extension hooks into VS Code’s task lifecycle using its extension API.
When a task finishes, it:
  1. Collects task name
  2. Determines status (success / fail)
  3. Formats a JSON message
  4. Sends a broadcast UDP packet
Simplified Flow Diagram
| VS Code     |------>| notifybuildresult  |----->| UDP Broadcast (10203) |
| Task Finish |       | Extension          |      | JSON Payload          |
+-------------+       +--------------------+      +-----------------------+                                                             |                                                             v                                            +-----------------------------+                                            | Any Device Listening on LAN |                                            +-----------------------------+
📡 Example: ESP32 Build Light
Here’s the simplest ESP32 listener:
#include <WiFi.h>
#include <WiFiUdp.h>
#include <ArduinoJson.h>
WiFiUDP udp;
void setup() {  WiFi.begin("ssid", "password");  udp.begin(10203);
void loop() {  char buffer[256];  int len = udp.parsePacket();  if (len > 0) {    udp.read(buffer, len);    StaticJsonDocument<256> doc;    deserializeJson(doc, buffer);
    String status = doc["status"];    if (status == "success") digitalWrite(LED_BUILTIN, HIGH);    else digitalWrite(LED_BUILTIN, LOW);  }
The LED instantly flips green/red based on your build result.
💻 Node.js Listener (Desktop or Pi)
import dgram from "dgram";
const socket = dgram.createSocket("udp4");
socket.bind(10203, () => console.log("Listening for VS Code build results..."));
socket.on("message", (msg) => {  console.log("Build Event:", msg.toString());
One script, infinite possibilities.
🔨 How To Install the Extension
Install from GitHub:
git clone https://github.com/sdrshnptl/notifybuildresult
Or load it manually via VS Code → Extensions → "Install from VSIX".
Full instructions are in the repo.
🧱 Use Cases
✔ Build light for embedded developers ✔ Notify a CNC system (Fanuc, Modbus, ESP32 gateways) ✔ Update a wall display or dashboard ✔ Flash LEDs on your workbench ✔ Trigger home automation when CI breaks ✔ Play sound effects when builds fail
If you can listen to UDP, you can automate it.
🎯 Why I Built It
I work with a lot of embedded, IoT, and automation systems. Builds can take time, and I wanted a simple visual indicator that didn't require switching windows. Most notification systems are cloud-based or require too much overhead.
UDP broadcast is a beautifully simple local-only solution.
🚀 What’s Next
Planned features:
Pull requests welcome.
Repo again: https://github.com/sdrshnptl/notifybuildresult
Like
