JuiceMining: Affordable, Reliable Battery Gauging for Everyone
kevin-caiKevin Cai wrote 03/06/2026 at 20:59 • 2 min read • Like
Elevator Pitch: A "no-nonsense" battery fuel gauge board utilizing high-performance, cost-effective silicon to bring industrial-grade energy monitoring to DIY projects and humanitarian tech.
1. The "Why": The Gap in the Market
Precision battery monitoring is usually split into two extremes:
  1. Too Simple: Cheap voltmeters that "guess" capacity based on voltage (highly inaccurate under load).
  2. Too Complex: High-end chips from big-name vendors that require NDA-restricted tools, expensive development kits, and complex proprietary software.
JuiceMining fills the gap. I’m using a specialized, affordable gauge chip that I have personally tested and validated across multiple high-demand projects. It offers the precision of high-end solutions at a fraction of the cost.
2. The Solution: Hard-Earned Reliability
This project isn't about reinventing the algorithm—it’s about proven performance.
I have selected a specific gauge controller that balances cost and accuracy. While the internal algorithm is baked into the silicon, the hardware implementation, carrier board design, and communication libraries are fully open for the community to use.
Key Benefits to Society:
3. Technical Features (Draft)
4. What I’m Sharing (The Open-Source Part)
While the chip's internal logic is proprietary, I am open-sourcing everything else to ensure the community can build on this:
5. Project Goals
Like
