Elevator Pitch: A "no-nonsense" battery fuel gauge board utilizing high-performance, cost-effective silicon to bring industrial-grade energy monitoring to DIY projects and humanitarian tech.
1. The "Why": The Gap in the Market
Precision battery monitoring is usually split into two extremes:
- Too Simple: Cheap voltmeters that "guess" capacity based on voltage (highly inaccurate under load).
- Too Complex: High-end chips from big-name vendors that require NDA-restricted tools, expensive development kits, and complex proprietary software.
JuiceMining fills the gap. I’m using a specialized, affordable gauge chip that I have personally tested and validated across multiple high-demand projects. It offers the precision of high-end solutions at a fraction of the cost.
2. The Solution: Hard-Earned Reliability
This project isn't about reinventing the algorithm—it’s about proven performance.
I have selected a specific gauge controller that balances cost and accuracy. While the internal algorithm is baked into the silicon, the hardware implementation, carrier board design, and communication libraries are fully open for the community to use.
Key Benefits to Society:
- Cost-Effective Sustainability: By using affordable components, we can deploy these boards in large-scale battery recycling or off-grid solar projects where every cent counts.
- Plug-and-Play Intelligence: Get accurate State-of-Charge (SoC) data without needing a PhD in electrochemistry.
- Proven in the Field: This isn't a theoretical design; the core tech has been stressed-tested in real-world environments.
3. Technical Features (Draft)
- Core Logic: Dedicated hardware-based gas gauge (Optimized for Li-ion/LiFePO4).
- Interface: Simple I2C/Serial output for easy pairing with any MCU (ESP32, Arduino, STM32).
- Low Power: Minimal parasitic draw, making it perfect for long-term storage or small battery packs.
- Accuracy: Real-time compensation for temperature and discharge rates (much better than simple voltage-based indicators).
- Form Factor: Compact, breadboard-friendly, or ready-to-mount "module" style.
4. What I’m Sharing (The Open-Source Part)
While the chip's internal logic is proprietary, I am open-sourcing everything else to ensure the community can build on this:
- Verified Schematics: Optimized for low noise and high reliability.
- PCB Layouts: Tested thermal and signal integrity designs.
- Driver Libraries: Easy-to-use code to get the data out of the chip and onto your screen/cloud.
- Calibration Guides: Documentation on how to get the most out of this specific hardware.
5. Project Goals
- Milestone 1: Release the first "Generic" 1S (Single Cell) module. Provide a way to program the gauge to tailor for user's battery chemistry.
- Milestone 2: Provide a library for popular microcontrollers.
- Milestone 3: Develop a "Power Wall" version for multi-cell monitoring.
Kevin Cai
