Unknown HV Diode Testing
collin-matthewsCollin Matthews wrote 05/30/2026 at 15:15 • • 2 min read • Like
Recently got some high voltage diodes of unknown properties. Decided to measure their breakdown voltage and estimate their specs based on similar sized models. This was a bit challenging due to the high voltage nature and my measurement setup,for breakdown voltage I am rounding to the nominal standard diode voltages (within 1kV). The leakage current at high voltage my meter only incremented in 100nA, so we are limited, I would expect these are inline with other typical ~1990's-2000's HV diodes.
Diode Parts:
H1601-30 Specs:
Measured the forward voltage:
Measured Breakdown Voltage & Leakage:
CS140U10 Specs:
Like
