//Sketch to generate timing pulses to test the power meter (an attiny85 is used, but any arduino will do the job)
program to simulate the signal as generated from aa speedometer pickup by an arduino duemillenova
it will be fed into another arduino that contains the power measuring algorithm
const int speedpin = 2;
void setup () {
pinMode(speedpin,OUTPUT);
digitalWrite(speedpin, HIGH);
void loop()
{ for (int i=1;i < 40;i++)
digitalWrite(speedpin, LOW);
delay(1);
digitalWrite(speedpin,HIGH);
delay(400);
for (int i=1;i < 10;i++)
delay(5);
delay(400+i*10);
Gerard te Meerman
