Belt Lifted Z-Axis for 3D Printer
mark-rehorstMark Rehorst wrote 12/23/2017 at 03:11 • 1 min read • Like
My latest 3D printer design uses a belt lifted Z axis that has proven to be a very good performer.  The 300x300x8mm MIC6 bed and its support (3.5 kg) are lifted on two linear guides using two steel core belts.  The belts are driven by a NEMA-23 motor mounted on an OnDrives Rino 30:1 worm gear reducer that prevents the bed from dropping when power is shut off.  Maximum speed is 20 mm/sec (the motor is spinning at 333 rpm!), even with a 4 kg print load.  The motor is rated for 1.8A, but I operate it at 1A and it never gets more than 5C above ambient temperature.  It is driven directly by the driver chip on a SmoothieBoard controller.  I have measured belt stretch and determined that it is negligible.
More details of the Z axis design are found here.
UMMD Z-axis
Belt lifted Z axis for CoreXY printer
Like
Rich text editor
