SparkFun Shipment Review
compucatCompuCat wrote 08/30/2014 at 03:37 • 2 min read • Like
I thought I might as well share my thoughts on some new stuff I got from SparkFun.
First up: the 50 watt soldering station. Apart from the metal dome for the brass sponge in the iron holder being loose, it's a solid iron. Adjustable temperature, fine tip that can do SMD and PTH, a comfortable wand, and a sturdy holder. What more could you ask for?
Next: the Pocket AVR Programmer. This is a USBtinyISP rebranded and with some extra features. Showdown time!
Contestant #1: USBtinyISP
Contestant #2: Pocket AVR Programmer
First: Both programmers can supply 5 volts to the target or adjust to the target's voltage while not supplying power. However, SparkFun replaced Adafruit's removable jumper with a small switch. This point definitely goes to SparkFun.
The USBtinyISP has two cables: one for the older 10 pin header, and one for the new 6 pin header. SparkFun copies this, but consolidates both connectors on a single cable. The 6 pin connector is slightly looser, since some of the wires in the ribbon cable have to be cut away to "adapt" the 10 strand ribbon cable to a 6 pin IDC connector, but it's certainly better than having a second cable get in the way of what you're doing. SparkFun wins this round again.
SparkFun ships their programmer as a bare board. Adafruit actually ships theirs with a case. Adafruit's USBtinyISP wins this round, but anybody with access to Thingiverse and a 3D printer can solve this problem.
Also, Adafruit is the initial designer of the product, so they automatically get bonus points.
I prefer SparkFun's edition, personally, but I would enjoy using either programmer. Definitely a solid choice. Pair it with AVRDUDE and you can't go wrong.
Next: Binding posts. Some people have complained about their "cheapness". I think they work fine! Not too much to say here.
I also ordered various connectors (ATX, MIDI, 3.5 mm audio). All were perfect, but the audio and MIDI jacks had quite fat pins, making them hard to stick in a PCB. Still, they work!
SparkFun's MIDI cable is a good bargain and appears to be of good enough quality. After all, you don't need an outrageously expensive cable for 31250 baud serial!
Various resistors and diodes came as well: top-notch packaging, as always.
The 10k panel-mount potentiometers work perfectly: they have a solid action that doesn't feel cheap, and they'll stay in place and not "wobble" around. Perfect!
Overall: kudos again to SparkFun for making some perfect products and generally being an awesome company to buy from. Now, time to use these tools to finish up the airboat...
Like
Rich text editor
