Update 10/04/2019 - Getting to Blinky 5.0
Contextual Electronics just updated their tutorial series to KiCAD 5. I recommend that you start here.
https://www.youtube.com/watch?v=BVhWh3AsXQs&list=PLy2022BX6EspFAKBCgRuEuzapuz_4aJCn
[This area is out of date, leaving for posterity.]
Getting To Blinky 4.0
https://contextualelectronics.com/courses/getting-to-blinky/
This is where I recommend everyone start for learning KiCAD. It's an entirely step-by-step tutorial that gives you the foundational knowledge required for using KiCAD.
Keep in mind this Tutorial was written for KiCAD 4.0 and KiCAD 5.0 is a little different. I would recommend installing KiCAD 4.0, following Chris's tutorials, do a couple of simple projects for fun, then upgrade to KiCAD 5.0. Chris is working on an updated 5.0 series but if you want to start now that is what I would recommend.
[/end of out of date]
svg2shenzhen Inkscape Extension
This is the plugin that I talked extensively about and use a great deal for my projects.
https://github.com/badgeek/svg2shenzhen
How I make Shitty Add-ons
This is the stream I did in June on how to make SAOs.
PCB Color Reference Spreadsheet
This applies only to PCBWay, and is only meant to give you a rough idea of what to expect.
https://docs.google.com/spreadsheets/d/1dmkTsKZDV5iltQbpEa_QOL5XYEONms_M1ZETBNO5ub4/edit?usp=sharing
