DC DC Converters Board Mount
Device | Specifications | Sources |
Buck converter module | Input voltage : 4.5V - 28V Output voltage : 0.8 - 20V Output current : 3A Efficiency : 92% Switching frequency : 1MHz - 1.5MHz Operating temperature : -20°C - +85°C Size : 22 x 17 x 4 mm | WAVGAT XM1584 Driver IC : MP1584 |
Boost converter module | Input voltage : 2-24V Output voltage : 2-28V Output current & Efficiency Switching frequency : 1.2MHz Remark: high components, easily broken Size : 23 x 17 mm | HWA YEH SX1308 Driver IC : SX1308, pin compatible to MPS MP3221 |
Boost converter module | Input voltage : 2-24V Output voltage : 2-28V VIN=4.2V, VOUT=5V, Imax=0.5A (η=82%) VIN=3.7V, VOUT=5V, Imax=0.4A (η=82%) VIN=3.0V,VOUT=5V, Imax=0.3A (η=79%) Size: 30 x 17 x 14 mm | AliEpress 32851687094 Driver IC : MT3608 |
Boost converter IC | Consider using a boost LED driver. They are cheap, but might not have true output disconnect. Input voltage : 0.8 to 5.5V Output voltage : 2 to 5.5V Output current : 350mA EN = active high | * True output disconnect (1µA leakage): MCP1640 & MCP1640B not MCP1640C or D * MP3120 compatible to AAT1217 |
Buck boost converter module | Input voltage : 1.5-6.5V Output voltage : 3V3 Output current : * 1.5VIN -> 150mA * 3.7VIN -> TBD * 6.5VIN -> >3.0A Evaluation | AliExpress 32757272432 Driver IC : MicrOne ME2149 |
Buck boost converter module | Input voltage : 3-15V Output voltage : 3V3 Output current : ? | AliExpress 32892547111 |
3V3 LDO | * RT9080 (600mA, 2µA Iq) * Richtek RT9073N-33GB (3µA Iq, 0.6V dropout, Imax=250mA) * S-1313C33-M5T1U3 (200mA, 1.35µA Iq) * NCP718ASN330T1G (300mA, 4µA Iq) * HT7833 (LCSC C164106, SOT23-5) | Alternative : Holtek HT7333 (250mA, SOT89-3, Iq=5µA, 0.3V dropout) |
Load switches
If the MCP1640 consumes too much current to your mind (1000nA), then you can add a load switch. The TCK106AF,LF, TCK108AF,LF and TPS22917DBVR are excellent low power switches.
