Minibike Sort of Plans
actualdragonActualDragon wrote 06/03/2019 at 01:37 • 1 min read • Like
the lighting is bad, but i think that looks pretty cool, you can make out all the important parts
Like
MasterOfNull wrote 06/19/2019 at 20:19 point
Direct drive through a centrifugal clutch requires a small drive sprocket, a large rear sprocket, and a small tire size to get enough reduction to not burn it when you are starting out.
Carl Forgey wrote 06/05/2019 at 23:17 point
Are you doing a direct drive off of the driveshaft on the motor, or do you have some sort of transmission worked out?  If you're going for dead-simple a centrifugal clutch on the drive shaft would probably be just the thing.
ActualDragon wrote 06/09/2019 at 12:47 point
i have an engine with a horizontal driveshaft, Briggs and stratton 135202, so im going to put a chain and sprocket on there, with a gear on the wheel, probably pulled from an old mountain bike
