At night, the display will be off, allowing you to sleep in complete darkness. If you wanted to know the time, you could just wave your hand to light the display. After a minute, the display will go off again.
I see two possible sensor technologies : PIR & radar.
The RCWL-0516 radar module is cheap, offers 360° detection, but consumes 4mA continuously.
The HC-SR505 PIR module is also cheap, has a smaller opening angle and consumes only microamps continuously. More info can be found here. It should work on 3V3, but when I do that, it stays in an eternal detection state. 5V is definitely needed. A comparison of this PIR sensor to another one can be found here.
Christoph Tack
