Just a little list of things for me to aim for for this year:
- Complete DigiBone - i have an L shaped idea top prototype that I keep procrastinating over and it's time to stop doing that. Rather than having a full over-the-shoulder part the L shape will just have the mouthpiece area, the slide stock (where the ping sensors will be located) and then the speaker on the other side of the L, roughly in the position the bell would find itself.
- Complete my Pi Pedal - the pedal enclosure is built, and it's just a case of wiring it. Buttons to pi pins, power supply to Pi, then the case sockets to the HAT ins and outs.
- Explore another Pedal Idea - I have an Acer Revo Build that would sit nicely on a small pedalboard. It should run something like Guitar Rig, so building a large, Arduino-based foot controller for it would be something I'd like to pursue. Perhaps even de-casing a USB soundcard and housing it in the controller with a USB Hub could be on the cards
- Finish building Pi Cluster - the Pi boards should be in my possession in the next week or two, so putting the kit together and getting Kubernetes working will be the next phase. Also contemplating a new enclosure design for it; more rectangular. Screen to the left, with the Pis mounted to the right. The switch and its power brick underneath.
- Totem Maker Kit Review.
- Fix Totem Spider.
- Write up the NodeMCU wifi clock I made for my son.
- Write up and build the new Pi version I have planned.
- Finish Car Pi audio install - awaiting Mauseberry board
- Build Totem rack to hold din rails- triangular ends, beams to support. Cut din rail and mount the rail PoS and Nodemcu to the angled side, power modules to go on the back side rail. Face back side rail inwards to keep it small and tidy. Install arduino Mega w/ Ethernet or Wi-Fi shield in base with breadboard and potentially a small switch or access point. Will simplify development.
I'll add more as and when I think of them.
