Some manufacturers make low power AC-DC modules for small appliances, IoT devices and smart meters. MeanWell may come to mind (IRM-05-3.3), but one of the most cost-competitive modules is the Hi-Link HLK-PM03.
Here I will have a closer look at how the module is built. There are of course other teardowns out there, but not necessarily of the 3.3V variant, and you never know if you're going to find something others could not or had not seen.
Unpotting
So what's inside the HLK-PM03? With a silicone potting compound that readily unmoulds from the enclosure, the module was definitely inviting further investigation.
Quoting https://acc-silicones.com/products/primers:
"Silicone adhesives and some 2-part rubbers have built in adhesion promoters - with these products the use of a primer will only be required for use with substrates that are exceptionally difficult to bond to. Most 2-part silicone rubbers will not have any adhesive qualities and the use of a primer will be essential if adhesion is required."
I'm not seeing a lot of adhesion here, but the surface texture of the injection moulded plastic housing is reproduced flawlessly :) Slides right out of small gaps:
The inner sides of the black housing have a satin texture added to better retain the silicone block. It seems like good practice, but only early models will tell the tale whether the mould texture was added later in production.
Unfortunately I will not finish this article on account of the hackaday.io having deleted a good portion of the text, lost graphics and giving error 413 when I save the draft.
hackaday.io is no hacker's "platform". If you can put up with a text editor that loses your work over and over again, that's your choice. I won't condemn your masochism, but I won't share it.
