Arduino Workshop-Pulsating Lamp
mr-sarful-hassanMr. Sarful hassan wrote 06/14/2020 at 16:24 • • 5 min read • Like
Today I show you how to control your led brightness  its very easy work I show you step by step and it also calls Pulsating Lamp
Required Component for Arduino LED Chase Effect
1.Arduino
2.  5mm  LED
3. Resistors
This book will help you to gain more knowledge about Arduino
Beginning Arduino
Circuit diagram Pulsating Lamp:
Pulsating Lamp[/caption]
The circuit for this project is simply a green LED connecting, via a current-limiting resistor, between
ground and Digital Pin 11
Code Pulsating Lamp:
int ledPin = 11;
float sinVal;
int ledVal;
void setup() {
pinMode(ledPin, OUTPUT);
void loop() {
for (int x=0; x<180; x++) {
// convert degrees to radians then obtain sin value
sinVal = (sin(x*(3.1412/180)));
ledVal = int(sinVal*255);
analogWrite(ledPin, ledVal);
delay(25);
Verify and upload. You will now see your LED pulsate on and off steadily. Instead of a simple
on/off state, we are now adjusting its brightness. Let’s find out how this works
Code  Antonyms :
The code for this project is very simple but requires some explanation. We first set up the variables for the LED Pin, afloat (floating-point data type) for a sine wave value, and ledVal which will hold the integer value to send out to Pin 11. The concept here is that we are creating a sine wave and having the brightness of the LED follows the path of that wave. This is what makes the light pulsate instead of fading up to full brightness and back down again.
We use the sin() function, which is a mathematical function for the sine of an angle. We need to give the function the angle, expressed in radians. We have a for loop that goes from 0 to 179; we don’t want to go past halfway as this will take us into negative values, and the brightness value we need to put out to Pin 11 needs to be from 0 to 255 only. The sin() function requires the angle to be in radians, and not degrees, so the equation of x* (3.1412/180) will convert the degree angle into radians.
We then transfer the result to ledVal, multiplying it by 255 to give us our value. The result from the sin() function will be a number between −1 and 1, so we need to multiply that by 255 to give us our maximum brightness. We “cast” the floating-point value of signal into an integer by the use of int() in the statement level = int(sinVal*255); Then we send that value out to digital pin 11 using the statement analogWrite(ledPin, ledVal); Casting means to convert a value in one data type to a different data type (in this case, floating-point to integer, by throwing away the portion after the decimal point).
But, how can we send an analog value to a digital pin? Well, if we take a look at our Arduino and look at the digital pins, you can see that 6 of those pins (3, 5, 6, 9, 10 & 11) have PWM written next to them. Those pins differ from the remaining digital pins in that they are able to send out a PWM signal, which stands for pulse width modulation. PWM is a technique for getting analog results from digital means. On these pins, the Arduino sends out a rectangle wave by switching the pin on and off very fast. The pattern of on/offs can simulate a varying voltage between 0 and 5V. It does this by changing the amount of time that the output remains high (on) versus off (low).
The duration of the on-time is known as the pulse width. For example, if you were to send the value 0 out to pin 11 using analogWrite(), the ON period would be zero, or it would have a 0% duty cycle. If you were to send a value of 64 (25% of the maximum of 255), the pin would be ON for 25% of the time and OFF for 75% of the time.
The value of 191 would have a duty cycle of 75% and a value of 255 would have a duty cycle of 100%. The pulses run at a speed of approximately 500Hz, or 2 milliseconds each. So, from this, we can see in our sketch that the LED is being turned on and off very fast. If the duty cycle were 50% (a value of 127), then the LED would pulse on and off at 500Hz and would display at half the maximum brightness.
It is basically an illusion that we can use to our advantage. It allows us to use the digital pins to output a simulated analog value to our LEDs. Note that even though only 6 of the pins have the PWM function, you can easily write software to give a PWM output from all of the digital pins, if you wish.
ARDUINO TUTORIAL
Like
