This book will help you to gain more knowledge about Arduino
Beginning Arduino
Piezo Knock Sensor[/caption]
Code Arduino Piezo Knock Sensor :
int ledPin = 9; // LED on Digital Pin 9
int piezoPin = 5; // Piezo on Analog Pin 5
int threshold = 120; // The sensor value to reach before
activation
int sensorValue = 0; // A variable to store the value read from
the sensor
float ledValue = 0; // The brightness of the LED
void setup() {
pinMode(ledPin, OUTPUT); // Set the ledPin to an OUTPUT
// Flash the LED twice to show the program has started
digitalWrite(ledPin, HIGH); delay(150); digitalWrite(ledPin,
LOW); delay(150);
LOW); delay(150);
void loop() {
sensorValue = analogRead(piezoPin); // Read the value from
the sensor
if (sensorValue >= threshold) { // If knock detected set
brightness to max
ledValue = 255;
analogWrite(ledPin, int(ledValue) ); // Write brightness
value to LED
ledValue = ledValue - 0.05; // Dim the LED slowly
if (ledValue <= 0) { ledValue = 0;} // Make sure value does
not go below zero
After you have uploaded your code, the LED will flash quickly twice to show you that the program has started. You can now knock the sensor or squeeze it between your
fingers. Every time the Arduino detects a knock or squeeze, the LED will light up and then gently fade back down to off. The threshold value in the code was set for the piezo disc I used when building the project. You may need to set this to a higher or lower value depending on the type and size of the piezo you have used for your project. Lower is more sensitive and higher is less
ALL ARDUINO TUTORIAL
Mr. Sarful hassan
