Here is another simple recipe with minimum ingredients and work.
DIY bake chicken coating:
1 teaspoon bread crumb, 1/3 teaspoon of Chilli powder, 1/5 teaspoon salt (optional)
I used it to coat a couple of drum sticks.
I made the bread crumbs from the bread ends or stale bread. More details here.
According to wiki, Chilli powder is chili peppers and blended with other spices including cumin, onion, garlic powder, and sometimes salt.
Salad dressing mix (dry) are good alternative spice mix to try.
DIY Fries:
I washed a few potatoes, and use a kitchen gadget to cut them up into fries.
I cook them in a pot of boiling water for 8 minutes. Meanwhile I pre-heat the oven at 400F (200C).
and coated a cookie pan I bought from a dollar store with 1 teaspoon of oil.
When the potatoes are cooked, rinse them in cold water and drain the pot. I use one piece to brush the surface with oil. I spread the fries on the pan and sprinkle a bit of Italian herbs on top.
Put both the chicken and the fries in the oven for 20 minutes. Flip the chicken and fries and bake for another 15 minutes. The chicken should be done. Serve with vegetables, bread etc.
If the fries are not yet crunchy, they might need another 5 minutes.
