How to connect devices to the IoT With Wifi
enrgtechEnrgTech wrote 12/02/2020 at 13:17 • • 2 min read • Like
Internet of Things (IoT) is rapidly growing across the globe. Its application is now broadening into the various sectors of the economy from manufacturing to agriculture. Wi-Fi has played a critical role in this growth. IoT applications have numerous connectivity requirements with regards to data throughput, energy efficiency range, and cost of the device. Wi-Fi has often been an obvious choice. This can be attributed to the many reasons as discussed below;
Pros and cons of Wi-Fi
Pros
Cons
Required Hardware
To be able to connect an IoT device to Wi-Fi you need the following;
Required Software
There are numerous software programs and solutions are readily available. These programs help connect the IoT device to the Wi-Fi. They include;
Connecting devices to the IoT with Wi-Fi
Traditionally, many devices that consumers have been connecting to the Wi-Fi network have been equipped with displays, keyboards among other computing resources. However, many IoT devices don’t come equipped with these abilities. They require to be configured by smarter devices that can transmit the relevant configuration information to join the network. One way to connect such a device to the Wi-Fi is by using Wi-Fi protected setup (WPS) button on the IoT device if the wireless router has a WPS button as well. Press the button on the device and that on the router as well.
Alternatively, have the device appear on the access point with its SSID and passphrase supplied on the manufacturer’s quick start card. As such, when the device is plugged in and powered on, the devices’ SSID is broadcast thus is easily identified. The shortcoming of this approach is that it requires advanced technological expertise and is time-consuming. It’s also susceptible to a security breach.
Like
